I've just downsized my board and connected the pedals up to a Godlyke power supply and daisy chain. Tested it out and all the pedals worked fine except the Zendrive which caused a funny intermittent swooshing noise, not so much when you first hit the guitar strings but very audible on the decay. My larger board has a PP2 which won't fit on the Pedaltrain Mini without taking up masses of room on the top. I used the Godlyke for ages before I got the PP2 and never had a problem, but didn't have the Zendrive then. The pedal order is:
Polytune Mini > true bypass looper > TS9 > looper > Zendrive > OCD > Analogman chorus > Carbon Copy
I know three ODs is a bit OTT but I've been running the Zen and OCD with a FD2 for a couple of years on the larger board with no problem whatsoever.
Any idea why this is happening? Please let me know if you have any thoughts on the issue. Cheers.
