Time Travel
  • Emp_FabEmp_Fab Frets: 24543
    No.  Nothing like it at all sorry.
    Offset "(Emp) - a little heavy on the hyperbole."
  • octatonicoctatonic Frets: 33870
    I’m confused. Why would anyone want to revisit 2018?
    £5 says 2019 will be worse.
    Travelling backwards in time is not possible.  Travelling forwards at different rates is possible though.
    Anyone care to calculate at what latitude you would need to fly West at 500mph in order to remain 'stationary' in time?
  • scalino65scalino65 Frets: 261
    hang on though. If you were standing right on the exact north (or south) pole wouldnt it be all times at the same time? thats like, far out, man.
  • FretwiredFretwired Frets: 24602
    That's not strictly true ... ;-)
    edited January 2019
    Not currently possible is more accurate.
    Travelling forwards at different rates: If you mean time dilation then yes this demonstrably possible but it doesn't preclude time travel into the past.
    General relativity does provide scenarios where it is possible to go back in time, according to NASA- at least mathematically.
    We also don't know if wormholes are a thing yet, nor if cosmic strings, or infinite cylinder theory are.
    It isn't likely to happen in our lifetime.
    No.  It is true.  That article discusses an unproven hypothesis.  Time dilation, to the best of my knowledge, is a demonstrable phenomenon.
  • FunkfingersFunkfingers Frets: 14632
    No way am I taking that bet.
    'Vot eva happened to the Transylvanian Tvist?'
  • ICBMICBM Frets: 72807
    At quantum level. Backwards time travel at any larger scales is likely to be impossible, rather than a technological problem.
    Is that £5 at pre-Brexit or post-Brexit values?
  • Emp_Fab said:
    In reality, any plane that is near to a time-zone border today can experience this.  e.g. A flight heading West over Ireland at 23:59 will be in 2018 until midnight arrives, when it will be in 2019.  However, once it crosses the West coast of Ireland, it will move into the UTC -1 zone, which will be 23:XX back in 2018.
    Depending on the ground speed of the plane and the latitude it’s flying at, it will either end up back in 2019 if it fails to reach the next time zone within an hour, or - if it’s northerly (and fast) enough - stay in 2018 until it lands.
    I'm surprised Ryanair don't offer annual Irish Time Travel Experience flights. :)
  • prowlaprowla Frets: 4977
    That article kinda glosses over the actual problem inherent with the very beginning of their idea - the supermassive black hole and its negative counterpart. Sure, you could create the wormhole, but in order to actually use it you'd have to - at some point - end up inside the event horizon of a black hole.
    As I understand it, that's not an especially comfortable place to be.
    <space for hire>
  • RaymondLinRaymondLin Frets: 11994
    Back in when concord was in operation you could in theory celebrate New Years in London then go to NYC and do it all over again.
  • quarkyquarky Frets: 2777
    Fretwired said:
    Cool, but its not technically time travel though ....
    Just being a pedant, but it probably is. Because of the general theory of relativity and the constant speed of light, you can imagine that you are always moving at a constant speed through space/time. As your speed in space approaches the speed of light, it distorts your speed through time.
    Admittedly, there would be measurable effect on a commercial jet crossing the date/line, but there must be *some* effect :)
    The ancient Greeks never thought man would set foot on the Moon. Our knowledge of science is limited so who knows what maybe be possible.
  • PhilW1PhilW1 Frets: 943
    edited January 2019
    If I could turn  back time I would never have bought that fuckin time machine.
    But time "on the clock" and when years start and end address surely made up concepts so measuring an absolute truth by them is moot.
     Wherever you like, just take the battery out of your watch
    soundcloud.com/thecolourbox-1
    Absolutely not. Time measured on a super-accurate watch would be different from someone who flew at speeds approaching the speed of light for a short distance than for someone who didn't, when they both got back together.
