For sale:
2 piece mahogany HH Tele body from Guitarbuild.
This has been pro finished in thin skin nitro and is starting to show signs of wear.
Comes fitted with a Gotoh bridge with brass saddles and is pre-wires with a Switchcraft Switch and a single CTS 500K volume pot.
Unfortunately when I was drilling the hole for the bridge ground wire I accidentally drilled through the body so there is a small hole on the revers (see pics)
All you need to do is wire in a set of your favourite humbuckers and bolt on a neck!
£160 Ono SOLD (pending the usual)
Based in London but happy to post!
Some pics:
