them again
ecc83ecc83 Frets: 1640
I post it just for interest and, (I hope reasoned) comment. I am personally averse to single ended designs. The single EL84 in a cheap practice amp makes sense, sort of but if you want 10 watts+ push -pull is more efficient, transformers are cheaper and they have far better power supply noise rejection.
Dave.
  • Inevitably someone will point out that this is in the posted in the wrong section. Probably best to just move it now before they do.
  • hywelghywelg Frets: 4305
    My ears can't unhear that el84 hard edge to the treble response.
  • ecc83ecc83 Frets: 1640
    Oh! I thought they were EL34, 6L6 and possibly KT88? Will check.
    Dave.
  • prowlaprowla Frets: 4970
    Dangerous killer hooligan...
    The 10th Anniversary amps feature:
    • ECC83 valve in the preamp stage
    • Specially voiced EL34, 6L6 and KT-88 power amplifiers
    • Clean and Boost or Overdrive settings, which are footswitchable
    • Specially voiced Reverb, speaker emulated output and effects loop
    • A super cool retro styling
    • A Celestion 70/80 loudspeaker
    Yus, no EL84.
    Dave.
  • Yeah they sound alright but be good to see some demonstrations without the talking :)
    soundcloud.com/thecolourbox-1
    Quite agree!  I also wonder why they put an 80W speaker in an amp that could never kick more than 12 watts or so? (unlike p-p designs) I also think the 70/80 is on on ICBM's hit list?
    Dave.
  • mbembe Frets: 1840
    I'm gonna buy 11 tomorrow 'cause that's 1 louder than 10. Right?
  • stickyfiddlestickyfiddle Frets: 27272
    I like the EL84 thing but didn't hear it in those clips.
    I thought the 6L6 one sounded quite good on the vid, fwiw.
  • ICBMICBM Frets: 72685
    There's a definite different characteristic to the sound, and I do actually like the typical sound of a single-ended amp with a big valve - I'm not sure why, although I suspect it might actually have something to do with the greater hum!
    As we've always said, probably much cheapness...
    Otherwise it's a strange choice for such a low-powered amp - or in fact any amp that you want to sound lively at whatever power level. It's usually thought of as a good choice for modelling amps because it's rather stiff and flat-sounding, so it doesn't tend to colour the sound in a particular way.
    There are now other Celestions which don't cost a fortune that they could have used though, not least the V-Type which I think they already are using in the Artist series. Using up old stock perhaps?
    Likewise - I hear quite a tight sound... but that's typical of Blackstar rather than typical of EL84s. I still think it sounds better than anything I've heard from them before.
    Still not keen on top-mounted controls though!
  • impmannimpmann Frets: 12683
    edited January 2019
