https://i.imgur.com/41PibNU.jpg
You're already losing this fella, lol. The "I'll just change this" becomes "Well now that doesn't sound as good with the new drive, so I'll just change this". Next thing you know you'll be scrapping the whole thing and buying a Helix a you're fed up of all the faff. Before long you'll realise that although the Helix sounds great, you're not a fan of menu's and you just want the simplicity of pedals again, and the first thing you'll look to buy is that Ultimate Drive and Avalanche run that you remember worked so well when you started out on this journey 3 months previous.
It never ends
Feedback can be found here http://www.thefretboard.co.uk/discussion/comment/908933#Comment_908933
Is this just limited to pedals or do we have to stick with the same board, patch cables and power supply?
I think I can do this. I had the best guitar tone I've ever had in my wedding band at Hogmanay and think I finally cracked stacking (Juansolo Klone into Digitech HardWire CM-2 into TC Dark Matter). I barely moved my guitar volume control (and I'm a habitual fiddler) and my strat finally sounded full and creamy rather than spiky and thin. Happy days. For delay I use a DD7 and wobble comes from a TC Flashback mini set to Chorus. All sitting on a Pedaltrain jnr and powered by a One Spot.
I think I can live with that for a year, unless something breaks.
I'm in. Mooer Red Truck, good enough for RJ Ronquillo on his European fly gigs so should be ok for me....and it's more pedal board that multi fx to me.....oh and a wah.
Feedback
I've always thought that if it's set up, then why would you want to change the cables, board or power supply?? Seems like unnecessary faff
I'll be keeping it all the same
Rules are very important in this kind of competition.
Haha, I wasn't seeing it as a competition. It's a challenge, and being successful means I get a greater prize than any other, being able to say I told you so to my wife (oh and I might get better at playing as well)
Although I’m toying with the notion of a slightly bigger board with compressor and chorus on it. Which would then get me thinking about a second drive pedal...
This is it for the rest of the year and I've got a lot of booking with the wedding band to make the most of it.
https://i.imgur.com/o0GdDhV.jpg
My set up is pretty settled now, and I don't have any money, so . . . no chance !
I sent a message half an hour ago regarding a pedal I'd like to own
I may however try and do a february-february challenge instead.
In December I went from a big board to a Nano Plus and I want to keep it this way for a while.
can I get a do over?
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
