Y Malmsteen
But I do like bass with a bit of wallop, and you can lose that if you're not careful.
Proper bass drive in the proper way.
https://youtu.be/59m6BoEVkng
He probably hasn’t got to be such a great player and part of the band without knowing what works for the song. A little time, with a little support to work through and experience the extremes and it’ll probably settle into a much more subtle trend. Hopefully?
P or J or buckers?
Flats or rounds or tapes?
Tone up or tone down?
modern clean amp or old valve warm?
Front pickup or back or both?
Fingers, slap, plectrum?
No such thing as a pure bass tone. Even on a DB the tone from finger tips or using the whole side of the finger gives a very different tone.
Saying Bass straight into an amp is as wide ranging as saying guitar straight into an amp.
Strat into Fender Princeton or Jackson Soloist into a Dual Rec?
Which is odd, since I like the Rickenbacker stereo system, so you can put one pickup through effects and the other not, if you want. That seems to work well for me, whereas splitting one signal and remixing it doesn't. I don't know why!
