Should I run a mile? LP heel break content
ricorico Frets: 1220
Hi all, in the quest for a beater I have seen a LP Studio on Crap Converters' Scunthorpe eBay site.
Does this look like a full on heel break?
Cheers!
  • johnljohnl Frets: 2011
    The money they're asking is about what unbroken studios go for - honestly don't think one as beaten up as that is worth the money.
  • ricorico Frets: 1220
    You see that's I thought until I kept seeing them circa £700. Early/mid 90s are my target years.
  • SteveRobinsonSteveRobinson Frets: 7041
    Yes, the neck has been detached from the body. It must have been some whack.
  • ICBMICBM Frets: 72471
    Yes.
    That depends on how well attached it was in the first place...
  • FunkfingersFunkfingers Frets: 14491
    The cost of a proper repair and respray is more than the guitar, as seen, is worth.
    I received the below reply from their eBay man, Ryan:
    ’Hi there good morning no it hasn't had a break there is a slit split in the wood I would say from age but not a break.
    Many thanks Ryan’
  • mikeyrob73mikeyrob73 Frets: 4671
    Many thanks Ryan’
    Run away
  • Simon_MSimon_M Frets: 542
    Ryan is full of shit.
    1reaction image LOL 0reaction image Wow! 9reaction image Wisdom
    More eloquently put. I was going to say, Ryan is a lying cnut!
    The Swamp City Shakers
  • GuyRGuyR Frets: 1351
    If they remove cash converters from Scunthorpe they will have to rename it Shorpe
  • Th4fonzTh4fonz Frets: 246
    I saw that on ebay I passed lol
  • heel break.
    Ryan is lyin'
    I sometimes think, therefore I am intermittent
  • It’s badly broken. I might pay  up to £250 for it as a diy repair project, it would probably make no economical sense at all if you were to pay someone to fix it.
  • octatonicoctatonic Frets: 33804
    edited January 2019
    Two miles, minimum.
    I'd then keep power walking.
    It does depend to a degree on whether it's been glued properly, and if not, what with... the cutaway side looks very tight, but I'm less sure about the bass side. If it's not tight it will be a right pig to re-do if the glue isn't the right sort.
    It also depends on the original joint - it's *very* unusual for a Les Paul to come apart at the neck joint instead of breaking at the headstock, so I suspect it was like that Special in the pics above - a very poor fit with shims. Unless it's now been properly shimmed and glued thoroughly, it will always be weak. And there's no way of telling without taking it apart again... unless you know a friendly radiologist.
    So I think Henrytwang's valuation is about right, or even a bit high.
  • equalsqlequalsql Frets: 6141
    It does look like it's been 'Townsended'. Walk away.
  • Looks like it was used in a game of cricket.
