While the rest of the world went jcm800 crazy.......
  • ICBMICBM Frets: 72409
    impmann said:
    80s amps? Guaranteed to ruffle ICBMs feathers but the Sessionette 75 needs to be in there...
    Probably :).
    Got two of them in for some work just now actually - a really early one with the glitter grille and a slightly later one with the string-vest grille. The glitter one sounds a bit better, possibly because it has a G12H-100 instead of the G12K-85 - not sure if that's original. Or maybe it's the ILP power module…
    I can *almost* get a sound I like out of the glitter one ;).
  • 1nten5e1nten5e Frets: 245
    80's......I went from a Lab Series L5 to a JC120 and that saw me into the 90's :)
  • richardhomerrichardhomer Frets: 24809
    I was using a Music Man 65 410 during this period (a sort of 'Super Reverb' of the day).
    Clearly my tonal preferences were not in Marshall territory. A great sounding amp that never failed....
  • drwiddlydrwiddly Frets: 918
    edited April 2014
    I had a 50w Marshall MV combo (fantastic sounding thing - one of the best amps I've ever owned) and an Orange OR80 combo as a back up. Marshall was nicked so I popped the Orange in for a Marshall 100w MV head & 4x12. Traded that a few years on for an AC30 + cash which saw me through to the 90's.
  • Zodiac51Zodiac51 Frets: 340
    All the hip cats were running around town with their Gallien-Kruegers & Sessionettes :D
  • impmannimpmann Frets: 12667
    Wow... was I a 'hip cat', then?
    GK amps... yep, I'd forgotten those. I saw Gary Moore at the Hammersmith Odeon back in the day, and I'm sure he had a GK amp set up...
    impmann said:
    GK amps..
    Awful things. Unbelievably loud in their time for such a small amp (well before the modern Class D mini-amps) but completely toneless in my opinion - or you could use the built-in chorus which sort-of made it sound better... if you like chorus!
    A lot of them failed too. I had one of the bass ones, it sounded not too bad at home, but at gig volume the sound went out about a foot and stopped there - no projection or space filling whatever. Then it died... I fixed it and got rid.
  • FX_MunkeeFX_Munkee Frets: 2478
    I was using a Hafler pre-amp and a Midiverb into one of those SS Marshall power amps for quite a while.
    Sounded perfect.... for the decade.
    As for sleeper amps, I'd like to try a Peavey Triumph again. To check the sound in my memory is actually as good as it was.
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
  • KarlosKarlos Frets: 512
    Lodious said:
    I guess there was a pretty short window before ADA MP1 and a quadraverb became the dogs twitcher....dark days indeed.
    When flogged my JCM and went with the ADA MP1 and Quadraverb GT, I was using a Marshall 9000 Series power amp, the big 4U green monster.
    Now that WAS a back breaker.
    (the artist formerly known as KarlosSantos)
    No mention of the Roland Jazz Chorus from the 80s?
    Best solid state amp ever, weighed more than a volvo though.
    I think you'll find it's been mentioned a couple of times :D
    helps when you read things!
  • thomasw88thomasw88 Frets: 2328
    Gigged a Yamaha G100 for most of the 90s.,  I was happy with that, a korg a4, and a japanese strat for about 6 or 7 years.
    then the gas man strucketh..
    What about the roland bolt amp.  great little hybrid ss/valve amp. terrible drive channel, but a clean channel to die for..
  • kelvinburnkelvinburn Frets: 156
    My friend has a silver pannelled Peavey classic 100 2x12 that may be from about then. Lovely sounding thing, like this;
    http://guitarmike.com/peaveycombo.jpg
    Those are nice - although the Classic is a 50W, it's the Deuce which is 100W. Valve power amp, solid-state preamp and a fantastic onboard phaser! (Tremolo on the very earliest models if I remember right.) The clean sound is fantastic and very Fender-like, the overdrive is a bit more of an acquired taste - essentially the same as the Bandit etc of the same era. They're pretty reliable, weigh a lot and sell for very little these days...
    Could you use a preamp type setup running straight into the power amp?  IE 6l6 valve power amp with modeller or SS preamp of choice?
    Yes.
  • :D
    I'm sure the clean sounds great as it is, but I reckon an AMT P1 might sound a bit better than the old style Bandit esque drive, so maybe it's possible to use a splitter and run between the clean preamp and an AMT running into the power amp.
    They really do go cheap... I'm a bit shocked, actually.
    The Deuce in particular can sell for little more than the value of the original quad of Peavey-labelled Sylvania 6L6GCs they sometimes still contain.
  • LoobsLoobs Frets: 3832
    Peavey VTM
