Cleaning strat bridge saddles
The bridge saddles on my Strat attract o lot of dust and I find it difficult to get in amongst them to clean. I've never taken them all off and am reluctant to do so and have to mess around with the intonation. I suppose I could measure the position of each one before taking them off.
Do you ever take them off for a proper clean? Or is there a good way to clean and keep em on?
    Compressed air will get the fluff out but not the grime. Dry scrubbing with a toothbrush will get more off but not every nook and cranny.
    Yes, I do take my bridges apart occasionally and scrub every individual part, including the screws, in soapy water with a toothbrush. They will end up looking like new, but the downside is that you will need to do a setup afterwards, or at least check it’s still good.
  • MagicPigDetectiveMagicPigDetective Frets: 3031
    edited January 2019
    Thanks  @Maynehead ;  I’ll give it a go and take it apart. There’s almost 3 years of crud there so it needs doing.
  • Thanks  @Maynehead ;  I’ll give it a go and take it apart. There’s almost 3 years of crud there so it needs doing.
    Do some measurements - height of saddles, how far extended etc so it’s not such a pain setting it up again afterwards.
    Personally i’d just take the strings off and just go in with a dry/damp toothbrush in situ.
  • guitars4youguitars4you Frets: 14294
    Tooth brush is useful
    If you dismantle and not sure what to do then yes one string at a time and then you can use the next saddle as the barometer to re-set
    Not sure though why you need to take out intonation and height screws - It is a good idea from time to time to turn let/right or up/down a half turn and leave as is, just to stop them 'locking up'
  • Thanks all. I dismantled it last night; it needed doing as there was a lot of dust underneath and grime inside the saddles. Washed with a toothbrush and warm soapy water, now looking like new. I took measurements and tonight I'll check the intonation.
  • TheMarlinTheMarlin Frets: 7882
    You’re cleaning all mojo out of it ;)
  • ESBlondeESBlonde Frets: 3590
    3  years?
    Can you pop round and have a go at some of mine, bring a can of WD40 and a selection of toothbrushes.
    I'm far too busy playing them to spend hours on OCD cleaning.
    On the other hand (ahem) I cannot play guitar with dirty or greasy hands, after setting up and handling cables I have to wash my hands before playing. So I'm hardly in a position to speak as it were.
  • ESBlonde said:
    Thanks  @Maynehead ;;  I’ll give it a go and take it apart. There’s almost 3 years of crud there so it needs doing.
    3  years?
    In my defence against accusations of OCD cleaning; I hadn't changed the strings for 8 months! . I’m getting the nut sauce out tonight tho, so maybe I do have a problem....
  • SNAKEBITESNAKEBITE Frets: 1075
    I think the secret is don't let it build up.
    A regular dust off with a paintbrush is far easier than a full strip down.
