If someone her can do this or knows someone who can, please let me know.
It all looks a bit "bedroom" to me. I would hate to have to operate the two switches that close together on stage.
If so the Boss spare parts dept can sort you out another Boss footswitch, you can drill that one instead, they're interchangeable
I did this years ago when I added a tap tempo switch to a DD-7, worked great.
Fitting it on the battery side would be a lot more sensible, if you're using a power supply.
Although some of you here are concerned about the resale value, I would be happy to pay someone to drill a hole in my pedal and do the mod for me. And I don't care which side the switch would be, as long as it will be functional.
https://www.jhspedals.com/products/discontinued-rare/ibanez-tube-screamer-true-bypass/
I am not concerned about resale value, I just don't like hacking something to do a job which is easier and better done by another method, but if you're absolutely determined to do it then I would consider doing it for you if I can find a switch which will fit in the battery side without making a hole in the main pedal body. I'd prefer to use a replacement rocker from a scrap pedal, which would then make it reversible if you ever want to.
