First string I've had that don't get the little nibs from rubbing against the frets on the underside. Odd but good.
Fe3O4 has a higher Vickers hardness than Nickel, and also appears to be harder than commercial available nickel plated steel.
"For locking tuners, they are primarily designed for use with hex core strings, but can be set-up with round core strings too. Try to get at least one full turn of the string tail on the tuning post." - https://www.homeoftone.co.uk/blogs/news/gabriel-tenorio-round-core-strings-fitting-notes
