Klone alternative? (Or rather- Klone with less mids?
JamesSGBrownJamesSGBrown Frets: 234
Hi all! So I've been using a Frederic Effects Golden Eagle as my always-on, edge of breakup pedal and I've tried to grin and bear it but I can't anymore. It sounds great but not what I'm after- it flattens my tone somewhat and isn't particularly transparent. I'll keep it, but I want something that's less mid-heavy, but stacks well.
Many suggestions? I know the Wampler Tumnus Deluxe has the 3 band eq...
  • Modulus_AmpsModulus_Amps Frets: 2597
    Metalzone has less mids..... sorry,
    the Tumnus deluxe sounds amazing, still fairly mid heavy from what I remember.
    Have you tried the Gunshot?
    Whats your guitar / amp / signal chain ?   and what sort of target sound you after ?
    If its a pushed amp type sound youre after have you considered an eq pedal as an clean boost with real tweaking options ..
    imho  klones arent really transparent,  more mids focussed  - \something based around a Timmy circuit  maybe better option
  • paulphoenixpaulphoenix Frets: 141
    edited January 2019
    Timmy or a peacekeeper would be good options
  • Hi all! So I've been using a Frederic Effects Golden Eagle as my always-on, edge of breakup pedal and I've tried to grin and bear it but I can't anymore. It sounds great but not what I'm after- it flattens my tone somewhat and isn't particularly transparent. I'll keep it, but I want something that's less mid-heavy, but stacks well.
    Not a Klon but have you tried the Xotic EP Booster? Think I preferred the tone of the EP to my RYRA, from memory the Super Hard On on my ZVex Double Rock also sounded pretty damn good
  • Most importantly these both stacked well with other drives. The RYRA didn’t stack as well IMO
  • +1 for the Thorpy Peacekeeper. Such a powerful eq in that pedal that you can shape it for a huge range of sounds
  • Winny_PoohWinny_Pooh Frets: 7830
    edited January 2019
    Timmy
    Or a Clark gainster if you like a TS frequecy range but more open.
    TC booster could do too
  • TC Spark Boost
  • ^^^full size not mini^^^
  • I've got a Wampler Tumnus Deluxe, and it's superb.
  • It's got to be a Thorpy Peacekeeper, to be honest. That'll do exactly what you're looking for
  • Thorpy stuff looks cool but my God they're humongous!!
  • stickyfiddlestickyfiddle Frets: 27329
    Not so - now available in de-bigulated enclosures
    Anyone been over to TGP recently to see if anyone's claiming that the little ones "just don't sound as good"?
  • StuartMac290StuartMac290 Frets: 1474
    edited January 2019
    They're really not! They're not much bigger than the compact Origin Effects pedals, and the top mounted jacks make them use up about as much space as a Boss pedal
  • Jimbro66Jimbro66 Frets: 2431
    The J Rockett Blue Note is worth a look. Very transparent. Sensible controls. Timmy-ish but maybe even a little more transparent. The earlier versions have a switch that adds more mids and more drive but for me it’s an unnecessary feature. There’s no switch on the newer ones.
  • I'll try the Peacekeeper- the shop i work in stocks Thorpy. Thanks guys!
    -they're not. Even the older "big" enclosure Thorpy pedals only take up about the same room as a Boss pedal.
  • cbellangacbellanga Frets: 572
    Barber gain changer is another alternative.. great sounding pedal!
    You work in a guitar shop and have not tried all the thorpys. Mind boggled.
