Gave a skype theory lesson to a music producer the other night and just gave another one to an up-and-coming singer songwriter this evening. I’ve been trying out my new theory workbook, or at least chapter 1 and 2 of it, and it worked really well!
Both lessons have been fun and productive and both people have said they got a lot out of it. It’s just a hobby but really interesting to be doing it after work. Just thought I’d share! Roll on the next one.
Roland said: Scales are primarily a tool for categorising knowledge, not a rule for what can or cannot be played.
What areas were they interested in?
Well I have written the first few chapters which I believe is the best sequence for adults who don’t want to learn to read music to go through:
1) Notes and the major scale
2) The minor scale
3) Relative major & minor
4) Identifying the home note and whether a piece is major or minor
5) Harmonising the major scale
6) Harmonising the minor scale
7) Cadences and diatonic progressions
8) Progressions that break away from diatonic
9) Modes (relative and absolute)
10) Recognising modes - from the melody and from the harmony
11) Harmonic and Melodic minor
12) Circle of 5ths and keys
Next I’m going to write chapters on inversions, modulations, modes of melodic minor and other stuff; then I could go into types of music - jazz, blues etc, or discuss other scale systems, or tuning systems; not sure yet. Feel free to advise!
The music producer wanted to jump straight in at modes but it became evident we needed to go back to harmonising the scales. The songwriter wanted to start at Circle of 5ths, but we needed to go back to step 3 and got as far as cadences.
I am not sure whether C of 5 should come before or after modes. Probably before. But modes flows so nicely after cadences and progressions. I’ll see. Each chapter has loads of pictures and midi files you can click to hear the demonstrations, and it all worked really well
to the extent that you spend so much time early on.
why is not just part of modes ?
1) They form the majority of western music from 1450 up until at least the first half of the last century.
2) Most guitarists know that A minor and C major are somehow connected, so solidifying that before expanding the concept to the other 5 modes is helpful
3) Because you can think of Dorian and Phrygian as surrounding the ‘default’ mode of Aeolian (one has a sharpened note, the other a flattened one); and the same with respect to Lydian and Mixo surrounding Ionian.
3.5) And only then can you show that just like major is the relative of minor, so is lydian the relative of dorian, and mixolydian the relative of phrygian).
4) And finally because if you strip out the special notes (the 2 and 6 in minor, and the 4 and 7 in major), you get the pentatonics which most people know and can play, and can quickly understand how C major penta is related to A minor penta).
Or to say it in the other direction, if you started with penta and inserted the missing notes, the ones you would insert are the minor 6 and the major 2 (for minor), and the perfect 4 and sharp 7 (for major). Thus ending up with minor and major scales.
Edit - oh and because also when I introduce the scales as ladders (scala meaning ladder) with different spaced rungs, I introduce the intervals of major (2212221) and demonstrate why that sounds so settled (being two groups of 221).
The cycle of 5th might work in / after cadences and diatonic progressions, as it is in it's basic form a never ending cycle of perfect cadences. It can of course always be revisted in another context later.
The area of theory I would like to know more about is jazz harmony, especially with regards to arranging for other instruments. What of course I would do with this knowledge is of course a moot point!
- secondary dominants (great for songwriting!)
I think these two work great in your course. Slightly more advance but still very usable for all types of music
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Secondary dominants I’ve already got after perfect cadences, in the section about non diatonic chords, and then again in circle of 5ths
Regards to the cycle of 5ths, I agree before modes. I’d probably nestle it between 7 & 8 as the student learns 7, sees how that expands with cycle of 5ths and then can use that info when working on 8 if that makes sense? But that’s just my initial thoughts. In any case it’ll probably be a little trial and error before you find a good place for it.
Corrected
Yep I’m inclined to agree
Having said that, I have picked some really cool concepts from the head of jazz at King's college, who used to come in the shop.
He showed some ideas used to harmonize the blues scale, which is course impossible using notes solely from the blues scale (well you could do it but it would sound hideous!), and were pioneered by people like Duke Ellington.
Essentially the blues scale notes are used as the extensions. I've then gone back and analysed a couple of Kenny Burrell tunes that we have played from time to time, Chitlins Con Carne and Midnight Blue.
For example Midnight Blue is a blues in Fm, and the II chord is a G7#9b13. If you look at the notes of the F blues scale and relate these to the II chord, Eb is the b13, F is the b7, Ab is the b9, Bb is the #9 and B is the 3rd, so the choice of chord extensions are determined by blues scale of the key of the song, and this why the blues scale works very well over this chord.
Chitlins Con Carne is in C, but the I chord is a C7#9, and the #9 is from the C blues scale.
I was also shown a really cool I VI II V turnaround with a very simply blues scale melody as the top line (this might require some thought to explain it). You can hear this approach really coming to fore in big band arrangements.
Haha
The thing is, it’s like maths, you have to start at 2+2, and everything unfolds from there. It’s difficult if you try and step in at advanced level.
