Quasimodo Les Paul Query
HarrySevenHarrySeven Frets: 8033
edited January 2019 in Making & Modding
Probably one for @WezV, @ICBM, @SteveRobinson, etc...
Been offered a nice-quality ‘70’s MIJ LP which is right up my street. However, it’s suffering from a hump in the neck (post-body joint). Seen this many times before on a variety of guitars.
Previous experience tells me this is either a quick fix (fret dress) or a proper job (frets out, level the board and refret).
Any idea re. a current ballpark figure for either of the above strategies?
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • FunkfingersFunkfingers Frets: 14592
    70’s MIJ LP
    From the Bell's Catalogue? ;)
  • ICBMICBM Frets: 72715
    Partial fret dress over the affected area if the rest is OK - £50
    Full fret dress if it's better to do the whole thing - £100
    Defret, level board, refret - £300 or so
    (Shop prices - a one-man workshop might charge a bit less.)
  • HarrySevenHarrySeven Frets: 8033
    Ta! :)
  • SteveRobinsonSteveRobinson Frets: 7086
    I really must revise my pricing structure!
    I know... I typed that and then thought "What? That's far too much!" But actually it isn't. It's 2019... when a decent pint in a pub or a cup of fancy coffee costs about a fiver.
    I charge £40 per hour which I think is about standard these days, and although technically the 'work' in the partial fret dress should only take about half that, by the time you've added in the initial playing/measuring assessment, done the work, probably re-strung it, a set-up at the end and a final playing assessment it's going to be an hour from case open to case closed even on a good day. And a shop will have to add VAT on that as well, even assuming a sole trader isn't VAT-registered.
