Revival Drive vs new amp?
I'm probably kidding myself with this one but...
I have a Princeton at the moment which I love but I'm hankering after a low wattage Plexi  to compliment it.  I was wondering though if I might get away with picking up a Revival Drive to run through the Princeton instead.
Has anyone managed to try the Revival Drive through a Princeton and been able to compare it to a decent Plexi amp, and if so how close did it come?
  • koss59koss59 Frets: 848
    Aren’t they the same price as a used Cornell Plexi 5 or whatever it’s called?
    Facebook.com/nashvillesounduk/
  • JohnPerryJohnPerry Frets: 1622
    I have, and the answer is very, very close indeed.
    But, having owned a Cornell 18/20 at one point, getting the 7-watter is a decent shout given how much the Origin costs and if a Plexi tone is all you want.
    (Of course the Origin is capable of a lot of different OD tones and a magnificent bit of kit.)
    I can see how you thought it might be  but it's not necessarily a cost saving excerise, not that it would hurt. It would be good to save a bit of space though, and the Revival Drive does seem to offer all sorts of other tones to boot. Having said that I would be depriving myself of the opportunity to run amps in stereo.
    Cheers John. That's exactly the sort of insight I was looking for.
    I used to have a one of the older Plexi  7s and have regretted selling it. One of the newer ones with the additional power setting and a 12" speaker this time for maybe a bit more headroom would be probably make me very happy. BUT as you say the Revival Drive is capable of all sorts of other tones and that is very appealing.
  • DanRDanR Frets: 1041
    For a long time despite owning a Marshall half stack I was using a Fender Pro Jr with a Wampler Plexi Drive Deluxe for playing out.
    Get both. Then you can't be wrong
  • JohnPerry said:
    Spoken like a true gashead. :)
    While you are there, is the Revival Drive good for Tweed tones also?
    There's a lesson there somewhere if we went looking. :)
    Yes, the bigger tweeds certainly, though actually it does not quite nail a driven 5e3 like my Bearfoot Syod3 does. Not sure why. Maybe I just haven't managed to dial it in yet but I guess I would have found it by now.
    Its forte is Marshall and Fender tones, clean and driven, but it can replicate an Ac30/BadCat/Matchless-type too with some EQing.
    I would get the Custom if you can stretch to it. Good to have all the EQ options
  • @JohnPerry ;;  I snagged a 1x12 Plexi 7 yesterday. The speaker is 2 inches bigger but the cabinet is about twice the size of 1x10 version. It sounds huge as a result. I think it's going to be too much for home use, but we'll see.
  • This might be a bit left field but wouldn't an Atomic Ampli Firebox be a potential answer to this? Multiple amp choices including the ones you've mentioned
  • So, I've got a really dumb question...
    Is the Revival Drive an actual amp ?
    That is, could it be used as a back up with just a 1x12 speaker for example ? Or as a 2nd 'amp' in a 2 amp set up ?
    I don't think it has any kind of power amp, but can be plugged straight into a desk, iirc
  • lukedlblukedlb Frets: 488
    You’ll still need a power amp or run it to your di for authentic amp tones.
    I've not tried any of the Atomic stuff. Interesting..
