Marshall bluesbreaker
billandobillando Frets: 26
Iv been using a marshall bluesbreaker attenuated just a little at gigs non miced and sometimes I feel it doesn't cut through that well. I always play on 10. Does anybody else use one and have any suggestions? They seem a bit flabby at full volume.
  • hywelghywelg Frets: 4303
    That's a JTM  though, they do flub out when turned up. Try a solid state rectifier?
  • ICBMICBM Frets: 72419
    Yes, that will tighten up the bass response at full power. The type of rectifier you need is a straightforward plug-in diode rectifier, not a 'valve emulating' one with extra resistance. Easy to tell apart - the type you need should be no larger than the black plastic valve base.
  • p90foolp90fool Frets: 31618
    Just back it off a little? I always ran my non-mv Marshalls on 8, just before the onset of mush.
  • Modulus_AmpsModulus_Amps Frets: 2583
    Roll the bass back as much as you can handle too.
    If you are playing un-mic'd and can't hear yourself, can anyone else hear you?
  • I do have the bass almost at zero. I found it sounds great on my own but kind of thin with my band. Loud but didn't cut through.
  • TTBZTTBZ Frets: 2901
    Try boosting with a treble boost type pedal?
  • 57Deluxe57Deluxe Frets: 7339
    /\ like a Rangemaster!
    <Vintage BOSS Upgrades>
  • NerineNerine Frets: 2170
    Don't use the attenuator??
  • John_AJohn_A Frets: 3775
    That's just what JTM45's do, there are all sorts of mods to remove flub, trouble is they stop the amp sounding like a JTM.  Backing off the volume a bit and running the bass at zero is the best option, if it's not loud enough just buy another :)
  • shaunmshaunm Frets: 1598
    Or use a Bassman and a Strat. Flub is reduced and high end is there in abundance
    Sorry for the highjack but can this trick be used on a PRRI? More my curiosity than an actual problem but I wouldn’t mind trying it.
    Thanks.
  • DominicDominic Frets: 16103
    exactly this........any treble booster will do but ringmaster type circuit is perfect
    then you can wind the amp back a bit too
    You'll be pushing it on the voltages for the 6V6s - the Princeton runs them very high anyway.
    A good way of getting more headroom and less flub is the 'Stokes mod', but I've never done that on a reissue.
    In that case, I'll leave well alone! Thanks for the info.
    Thanks.
    Best way to firm the bass up in a PRRI, after changing the speaker is to swap the OT out.  The Allen TO20 works well is it is a drop in replacement.
    http://www.allenamps.com/trans.html
    Shameless plug, I have a solid state plug-in  rectifier in the classifieds
    http://thefretboard.co.uk/discussion/149448/solid-state-plug-in-rectifier-and-bias-probe#latest
  • Would changing the speakers not help, is it loaded with greenbacks?
    Yes, to some extend, but as I said earlier the more you do to it to remove the flub, speaker changes included, the less it sounds like a JTM45.
    I had one and modded the life out of it until it didnt flub, but sounded like a JCM800, which isnt a bad thing, but if you want a JCM800 it's easier to buy one, and if you want a JTM then put up with the flub.
    As pointed out turning the volume down a bit, reducing the bass and using single coils helps, but will sound very different to the thing ran flat out with humbuckers.
