R.
Eqd Speaker Cranker clone
The OD3 is very mild but you can also get an exploding speaker sort of sound by smashing the input with a tube screamer
Fancy trying this?
http://www.thefretboard.co.uk/discussion/107387/fs-eqd-speaker-cranker-clone
R.
As others have said, the Tumnus Deluxe is good. You might need to use the eq on it though. I put my acoustic through my pedal board the other day (for delay and reverb) and accidentally left the Tumnus Deluxe on (with the mid knob around 12 or 1 o'clock). It was all mid range until I turned the pedal off. It really does emphasise the mids unless you turn the mids right down. Fundamentally it is still a klone, and the Klon is a very mid heavy pedal.
You might be better off with an Xotic RC Booster. That's a great boost. If you turn the gain up, it can add a bit of hair.
very subtle
