Remind me of UK Voltage..OK to Use These Bulbs?
I'm just double checking really, I think they are OK to use but would feel more reassured with a 2nd opinion.
I ordered some GU10 Halogen Spotlight Bulbs on Amazon as I couldn't find any in stores. Only remaining stock is being sold now since Halogen is being cast into the pit of History.
The Bulbs have a 230V rating, I thought they would have been 240V. They have the CE mark on them, they are German "Profissimo" ones.
They have the correct 35 Watt rating I wanted, but my existing 35 Watt ones are 200 Lumen whereas these are 190 Lumen, is this not important?
I read on t'net that light fittings have a Voltage Rating, not sure what mine are 240 or 230....again, is it unimportant?
Thanks.
Only a Fool Would Say That.
  • ICBMICBM Frets: 72442
    All electrical products sold in the EU must be 230V now.
    You probably won't notice a difference of 10 lumens. If it's a problem, buy LED... more efficient and brighter if you want it.
  • Thanks @ICBM I suppose the Fitting is OK too as it would house 2 x 240V Bulbs and 1 230V Bulb if I replace 1 of them.
    There is no difference. It's purely a matter of the way the voltage is defined - the tolerances were simply widened to include both 240V (UK and Ireland) and 220V (continental Europe), calling it 230V, but nothing actually changed.
    It can make a difference with some valve amps, but not a light bulb.
    Ok, Ta Muchly!
  • Simon_MSimon_M Frets: 542
    The voltage found in UK home varies quite considerably anyway. Lowest I’ve seen is about 225V, highest over 250V. Long story short, your lightbulbs are fine.
    Source: am spark.
  • spark240spark240 Frets: 2084
    Image result for electric shock gif
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
    Yep, that's about right ;)
    “BECAUSE I’M HOMER SIMPSON!”
