Pedalboard overhang therapy group
https://flic.kr/p/2eCfBXw
AAAAAAAARGH! It’s hanging off both ends! I can’t decide between the two drive pedals! The plug sticks out! It’s a bit tight in the case! Please don’t make me turn the tremolo sideways!
*whimper*
  • ‘You’re gonna need a bigger board’ - Roy Scheider.
    'Vot eva happened to the Transylvanian Tvist?'
  • LebarqueLebarque Frets: 3840
    The pedalboard equivalent of 'muffin top'.
    Surely you can get the pedals closer together by staggering them?
  • noisepolluternoisepolluter Frets: 798
    edited February 2019
    Or a smaller Rat-type pedal
    Or a Thorpy Warthog mini would sit nicely...
  • 57Deluxe57Deluxe Frets: 7339
    rotate both the polytune and BB 90 degrees then you will only have one overhang at least.
    (thinking.... this is Pedal Tetris!)
    <Vintage BOSS Upgrades>
  • PhiltrePhiltre Frets: 4173
    Good job there's no OCD pedal on that, it would mess with my, er, OCD.
  • breadfanbreadfan Frets: 379
    Get rid of the pedal tuner and use a Polutune Clip instead.
  • Get a polytune headstock tuner
    Perverts.
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • english_bobenglish_bob Frets: 5142
    Sideways tuners on pedalboards do my nut like nothing else.
    Any other pedal can go however you like, but the entire point of having a tuner in the first place is for it to be visible and readable. If you put it sideways you're no better than those freaks with their headstock tuners.
  • Get one of the new Pedaltrain pedalboard tuners, that’ll sort it.
  • soma1975soma1975 Frets: 6691
    You disgust me.
  • TTBZTTBZ Frets: 2897
    I got a PT metro as I couldn't bear getting a nano+ and having the power plugs hanging over the edge ready to get snapped off.
  • Paul_CPaul_C Frets: 7786
    not as bad as this one, from @schrodinger1612 ; ;)
  • octatonicoctatonic Frets: 33793
    I've just invented a pedalboard that is 20% bigger than it looks.
    What really makes me itch is that I'm pretty sure it would all fit if it wasn't trying to upset people.
  • joetelejoetele Frets: 951
    Staggering and rather chubby TC Electronic and Fender pedals mean there's quite a bit of overhang on mine. And yes, the bag is getting a bit tight....
    MUSIC: Pale Blurs
  • sweepysweepy Frets: 4183
    Pedals placed Sideways are just wrong and my big gripe with mini pedals is that I don't have mini feet, so the foot switch spacing has to be so wide that I might as well have normal pedals
  • TimmyOTimmyO Frets: 7417
    I had to google what that was - what a brilliant idea!
    Red ones are better.
  • AlnicoAlnico Frets: 4616
    CDO !
    (Alphabetical order.)
  • revsorgrevsorg Frets: 880
    If you just looked at the pedalboard down on the floor you'd say "this imposter has no right to join the Overhang Therapy Group.
    Four of those pedals aren't even plugged in! (My power supply only has 8 x 9V outputs.  The Polytune is currently battery powered - woe is me).
    But look above in my effects loop sitting on the 2x12 - these two pedals are definitely overhanging.
