Peavey Classic 30 Tweed, any thoughts.
  • ICBMICBM Frets: 72410
    jpfamps said:
    Valve King is worse in my opinion; PCB mounted fuses in an amp where the PCB is tiresome to remove.
    I’ve done a few - just cut the wires and fit a holder above the PCB. No need to remove the board at all.
    The MkII Valve King PCB is a write-off if the ‘valve monitoring system’ goes up in smoke though, like the last one I worked on...
  • PhiltrePhiltre Frets: 4173
    Is that the "TSI™ tube monitoring with LED pass/fail indicator lights"?
    Same thing in the Classic 20 Mini head.
    Yes.
    A solution in search of a problem which becomes a real problem if a valve shorts and feeds high voltage through the monitor circuit.
    Yes.
    One of the reasons I bought my Peavey Classic 20 Mini Head new was because they have a 5 year extended warranty if you register the amp with them.
  • ive got a valveking 50w combo mk 1 version, ive had it a while but not used it much. im gonna gig it this weekend as my katana is out of action, anything i should be aware of?
    No, the VK MkI is very reliable.
    thanks
  • dilbertdilbert Frets: 203
    edited February 2019
    I've had a C30 for years and it's been totally reliable. I agree with the boxy sound with stock speaker and I resorted to a 1x12" cab, (I actually got by with an 8 ohm jobbee) and it upped the sound a treat and it takes pedals really well. I have to confess I prefer the HRDIII I now use, but the C30 gave me 8 years of reliable service and still looks and performs, well, better than 'er indoors.
  • Well, Steve Earle always gigs with them (C50)... just sayin’
    The C50 and C30 are completely different amps. The C50 is good...
  • martinwmartinw Frets: 2149
    I've fixed an awful lot of broken Classic 30s.
    Once fitted with a decent mains transformer, and a few tweaks to voltages, they're ok. Ish.
    An amp with fundamental flaws.
