A decent capo?
NeilNeil Frets: 3627
Not usually a capo user but I've come across something I need to use one on one.
I dread marking any of my guitar necks
What are your suggestions?
  • FuengiFuengi Frets: 2850
    edited February 2019
    Kyser for my acoustic every time.
  • Being a bit of a traditionalist I use Shubb capos. They’re not as easy to fit quickly as some of the modern, ( and often more expensive), models but they do the job and I’ve never had one mark the neck.
  • crunchmancrunchman Frets: 11460
    I use G7th, which are one of the popular ones.  I've been using it on my Martin with a nitro finish neck for years and it hasn't caused any marking if you are worried about that.
    I know Kyser also have a good reputation.
    Steer clear of Shubb.  I sold all my Shubbs on Feebay when I got a G7th.  Unless you adjust the thumbwheel very carefully on a Shubb, you will get tuning problems.  The G7th sounds far more in tune than my Shubbs used to.
  • I like G7th for electric and Shubb for acoustic. Never had any issues with either
  • zepp76zepp76 Frets: 2534
    +1 on the G7th easy to use and hasnt left any marks on my guitars.
    Tomorrow will be a good day.
  • Th4fonzTh4fonz Frets: 246
    Kyser for my acoustic and shubb for my electric
  • The G7th is the only capo I've tried that doesn't force me to tweak the tuning once it's on. I've stuck one on mid-song before and checked the tuning afterwards to find it's absolutely dead on.
  • BowksBowks Frets: 414
    G7th for me. They are quick and simple to use, don't need too much pressure, affecting the tuning and are easy to remove.
    I've to Shubbs, Kysers, a Planet Waves NS Pro, but always end up using the G7th.
  • ICBMICBM Frets: 72442
    Kyser. No issues, ever.
  • Jimbro66Jimbro66 Frets: 2430
    Another vote for Kyser. I use them on fairly valuable guitars including my Atkin OM Retrospective without any harm to them at all. The Shubb capo is a faff. Kyser is so easy to use.
  • AlnicoAlnico Frets: 4616
    G7th
    Works perfectly and I like being able to choose how much pressure it applies.
    I only use it on electric, I don't play acoustic at all.
  • I use the Kyser quick change on the electric and the Dunlop trigger for acoustic. Served me well for many years.
  • NeilNeil Frets: 3627
    Thanks for the recommendations.
    Looks like a G7th will be in my future, pretty impressive.
    Thanks again.
  • mrkbmrkb Frets: 6883
    Thanks again.
    There’s a new G7th coming out, has better spread of the pressure across the neck, for when neck radius doesn’t match capo radius. So current stock should be sold off cheaper. Win win!
    Karma......
    Ebay mark7777_1
  • In the last 20 years this has been thr only capo I have used, never lost as it doesn't leave the neck .. Yamaha CP200 Solid Brass Acoustic Guitar Capo https://www.amazon.co.uk/dp/B000Y7Q27O/ref=cm_sw_r_cp_apa_i_fgWzCbZK0T2YH
  • NikcNikc Frets: 627
    Learn to play barr chords and never use one - the work of the devil they are
    Or planet waves simple and effective for not a lot of money I use them on acoustic and electric no issues
  • JerkMoansJerkMoans Frets: 8794
    My two penn’orth: Avoid the fancy Thalia jobbies: first time I used one it put a little ding in my soft v strat neck :(
    Inactivist Lefty Lawyer
     :o
  • DominicDominic Frets: 16103
    Agreed.......it's great
  • Got this one from Mr Knopfler - D'Addario NS Capo Pro best one I've found so far. http://www.accessories.daddario.com/pwProductDetail.Page?ActiveID=4115&productid=503&productname=NS_Capo_Pro_Black
