Scales
Hi
I've been playing guitar a while but have made the mistake of never really making scales part of my regular practice. I was wondering what scales and patterns should I start to work through and what scales I should aim to progress to once I have learned these?
  • Caffeine_VampireCaffeine_Vampire Frets: 3479
    edited February 2019
    No fixed rule but learning the 5 pentatonic patterns major and minor up and down the neck in different keys would be a good start. Use alternate picking and use a metronome.
    'Vot eva happened to the Transylvanian Tvist?'
  • FuengiFuengi Frets: 2850
    Personally, I went for the Natural Major and Natural Minor scales ensuring I learnt all the intervals.
    Still a way to go on the Natural Major Scale, but getting there on the Natural Minor and it's incredibly useful.
  • robertyroberty Frets: 10893
    +1
    Also +1 for justinguitar
    Once you know the pentatonic you only need to add a 2nd and a 6th and you've got a minor scale
  • KeikoKeiko Frets: 1012
    Guitar teachers always seem to make learning scales way too complicated. There are 7 notes in the major scale, and that's it.
    Maybe it's because I learned keyboard before I took up the guitar, but I never understood the need to learn all these complicated patterns and positions on the fretboard. So long as you learn where all the notes are on the fretboard (that's the hard part granted, but once it's done, it's done), the scales will come very easy to you - you only need to know the 7 notes of the scale. Then when someone asks you to play the major scale you can play it anywhere on the fretboard, without being trapped in positions and patterns you have learnt.
    Im not a guitar teacher so dont take my word for it, but thats how I learn't my scales, and it works for me.
  • I always do the minor pentatonic first as its the easiest to learn and most stuff will sound good provided its in key and you're playing the right intervals!
  • sev112sev112 Frets: 2778
    scales (and modes) are  easy to remember how to play  all based on one simple pattern and 2 rules
    starting from any fret, any string :
    XXYYZZX ad infintum (or just keep repeating if you have infinite strings - or 7 or 8 say) for a Major Scale
    shift up one fret when moving from X to Y
    shift up one fret if moving from a G string to a B string
    (X is frets 135, Y is 124, Z is 134)
    modes are are just as easy - same pattern, just different starting points in that pattern
    E.g. Minor / Aeolian start the pattern with ZZ, Lydian XY, Dorian ZX, Milo XXX etc)
    (source Michael Pillitiere)
  • close2uclose2u Frets: 997
    That is a long-term aim.
    Learn one pattern only to begin.
    Not just the fingering, the up / down, the pattern etc.
    But how to use it. What you can do with it. Learn licks, play licks, reshape licks. Create licks. Play over backing tracks. Etc.
    Then learn one more pattern. Do the same as before.
    And then learn how to connect the two positions you now know.
    Do all this before learning the 3rd pattern.
    And so on.
    That is the job of months - unless you have an 8-hour / day practice schedule.
  • RolandRoland Frets: 8733
    That’s how I learned. Then I added a few notes to get the minor scale. Then I realised that minor scales could mean Aeolian or Dorian. A bit later came Phrygian and melodic minor. After that adding the major third meant that I had access to a slew of major scales. It’s all incremental stuff, rather than being faced with a cliff face of scales and modes.
    Yeah, any guitarist should know the first position of the minor pentatonic at least. Then when you add 2nd's and 6th's etc you get different sounding flavours and can adjust to whatever chords you are playing over. Also if you move the minor pentatonic shape down 3 frets you instantly get the major pentatonic!!
    @Lestratcaster UP three frets?
    Depends what your interpretation of "up" is haha. For me to go down is to go lower, so moving your left fretting fingers to the left!
  • ClarkyClarky Frets: 3261
    I teach my students this:
    G major, 3 notes per string, all 7 patterns
    G major pentatonic, all 5 patterns
    their warmup is to play G maj linking all 7 patterns as a continuous exercise working through every pattern with the metronome in 1/4 notes and then again in 1/4 triplets from the pattern starting on the 3rd fret right up to the octave on the 15th
    then we do the same with the pentatonic shapes
    it's good for fingerboard knowledge, not only in G, because the relationships of patterns and fingerings gets burnt in.
    it's also good as a picking exercise because it's alt picked throughout and so you play a lot of notes against a click to make it all the way to the octave
    and good for aural perception.. hearing the scales and feeling where they are on the fingerboard when you fret the notes
    also.. G major fingering is exactly the same for its relative minor and associated modes.. so nail the fingering in one and you nail it for all.. that just leaves learning the context of minor / other modes rather than treating the location of the notes as something different for your motor skills to learn..
    additionally... as the student gets tidier and more proficient.. we gradually up the tempo to keep the pressure on the technique..
    when we look at repertoire and are looking at riffs and solos etc, I often see the penny drop "oh it's this shape" even though we'll be in a different key..
    it's great when they are learning songs and repeatedly encounter familiar fingerings as it helps what they are learning stick
  • carloscarlos Frets: 3451
    Your method is correct, of course, but doesn't really play to the strengths of the guitar.
    We're playing an instrument that makes transposing a breeze. I really don't want to have to figure out all the notes of, for example, Gb Major, when I can just see all the Gb's on the fretboard and put my patterns on top. Or see all the Gb's on the fretboard and put all the intervals on top. I don't want to see the Gb Major and have to go in my head: okay, it's 6 flats, so here's a Bb, here's the Eb, etc.
    I guess it's okay to do it that way if you are mostly in the same key throughout a piece, but for anything with chord changes I prefer the easy route.
    I know other instruments have to do it that way, but we don't, so why should we?
    Do you give them their Greek names at that point or leave that for later?
    No, @Clarky saves the Greek names for his guitars  (or they might by Norwegian gods or something like that)
    lmao.... awesome
    there are no Greek names..
    practicing the 7 different fingerings for G major is still G major, just starting from a different note..
    to my students I simply refer to them a 1st, 2nd, 3rd etc position
    context wise, the tonic is always G
    so this exercise has nothing to do with modes or anything like that..
    when we get into modes at a later time, I explain how the context changes
    this means that all 7 fingering patterns for the centre key of any given mode are already known and remain available
    and so in any given mode, the student can visualise the entire fingerboard based upon those 7 interlocking patterns
    it is therefore less to learn because the fingers already know where to go..
    it's then simply a case of getting the ear and mind to understand and get to grips with the new modal context
    just a thought to add...
    most folks seem to not find it too difficult to accept and understand that the major scale and the relative minor share the same pool of notes..
    they tend to be completely comfortable with the difference in tonality and are quite happy to to write, solo, improvise in major and minor keys..
    the funny thing is that modes behave in exactly the same way..
    a relative minor is simply a different key / scale to it's parent major key [and so shares the same note pool] that has it's own specific tonality or 'voice'..
    in that sense, modes are no different at all..
    and so modes don't need to be taught differently or in a special way..
    once the relative minor thing is fully understood, modes are just more of the same
  • vizviz Frets: 10708
    Wizzed.
