FS: Some quality pickups(Reduced) - SD Antiquity (SOLD) - SUHR ML Neck(SOLD) - JOE BARDEN HSS set
phase3phase3 Frets: 41
edited February 2019 in Parts £
Time to clear out the pickup cupboard a bit:
First up - Set of Seymour Antiquity 1  - so that's 2 x Texas Hot ( Neck & Middle RW) and 1 x Custom bridge.  The neck and middle read approx 6.3 and the bridge is approx 9.1. They're pretty 'aged' and have been in and out of various strats - but i'm pretty much HSS these days and it seems a shame to split them up - so this is a SET.  The sound is legendary ! ... they're not HOT as the name suggests - nor particularly 'texas' ... just fabulous vintage strat with a tiny bit more beef. Leads not cut so full length still there
SOLD (subject to usual) £140 inc postage
 https://imgur.com/a/jas5XdZ
Next:
Suhr ML Standard Neck  - as new - fitted to one guitar which i then sold - with original p/ups.  Fabulous BIG Landau sound...really clear and plenty of upper mids to cut through
SOLD £60 inc postage
https://imgur.com/a/lzAehZw
Next:
Joe Barden HSS set  TM8/15  Humbucker and S-Deluxe.
Frighteningly expensive pickups and touted as possibly the most detailed on the market.
Well .. yes they are ( both). Not for the faint-hearted, they're capable of wringing out every last nuance .. so you've got to get on top of your technique.  However , if you do  ...it's ALL there.
I found that pickup height is the critical element with these ... if you get them too close - they'll destroy you -- back them away and they get much much kinder and more traditional ... but there's still enough power to kick the amp should you wish.
They're about £150 EACH !! now .... ouch  - i'd prefer to sell as set but might split the HB &S-Deluxes
£180 inc postage
https://imgur.com/a/BggFA3B
