Hardware: is mine nickel or chrome?
How do I tell if the hardware on my partscaster. (Telecaster) is nickel or chrome?
I want to add some new parts - and I would very much like them to match...
  • JDEJDE Frets: 1092
    Is it tarnished or “cloudy” at all? If so, it’s nickel. If it’s untarnished and has a mirror-like sheen, it’s chrome.
  • stickyfiddlestickyfiddle Frets: 27286
    That only holds if it's more than a couple of year old and you haven't polished anything.
    Nickel tends to look warmer and more "yellowy", whereas chrome is a little more at the blue end of silver.  Chrome is usually the default option, especially for cheaper parts. Post a pic or 3 and we can probably tell you.
  • gavin_axecastergavin_axecaster Frets: 527
    ^Yep. Easiest is to find a known chrome part and compare. The difference should be obvious.
  • FunkfingersFunkfingers Frets: 14592
    Proper vintage Fenders have a mixture of both finishes. Old Klusons tend to be nickel. Control plates and bridge baseplates tend to be chrome.
    Have you got a photo?
  • jaymenonjaymenon Frets: 836
    Thanks guys for taking so much trouble to try and help...
    I'm away from home at present - will post a pic as son as I get home...
    Wow - I never knew that. So I suppose it doesn't matter if I 'mix and match' too...
    Thanks Gavin - that's very informative and clear...
