What can I run at 12V?
lincolnbluelincolnblue Frets: 294
I have just bought a Harley Benton Power Plant 2. One of my pedals (TC Nova Delay) requires 12V whereas everything else runs at 9V.
Is it safe to run anything at 12V (to make the most of the 500mA from the one output) or would that damage pedals requiring 9V?
  • mgawmgaw Frets: 5281
    depends what pedals, check their manufacturers advice, some of mine say 9v but are happy and better at 12v
  • octatonicoctatonic Frets: 33804
    What pedals do you own?
    Bit hard to tell you what you can run at 12v if you don't tell us what you have.
  • NorthernStompsNorthernStomps Frets: 398
    Plenty of pedals can be run at 12v or higher. But not all of them. Just check with the manufactuer before plugging it in
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • lincolnbluelincolnblue Frets: 294
    PolyTune 2
    Boss OC3
    Magnetic Effects - Black Moon
    EHX - Soul Food
    Emma Onomatopia
    Neunaber Stereo Wet
    TC Spark Mini
    Boo Instruments Chorus
    Source Audio Vertigo
    EHX 360
    Joyo PXL Live
    edited March 2019
    PolyTune 2
    Boss OC3
    EHX - Soul Food
    Emma Onomatopia
    Neunaber Stereo Wet
    TC Spark Mini
    EHX 360
    Joyo PXL Live
    I think the only ones there that can be run 12v are the Stereo Wet and the Spark Mini.
    Neunaber say this on their website:
    Is there an advantage to a 12V adapter rather than 9V? The only advantage is an additional 2.5 dB of dry-signal headroom. This is imperceptible under most circumstances; however, it may be appropriate for a line-level effects loop.
    You might want to ask them though.
    I know the non-mini Spark can be run at 12v as I did it.
  • soma1975soma1975 Frets: 6722
    Phwoar, the improved headroom on a Polytune2 run at 12v
  • ICBMICBM Frets: 72472
    If the 12V is accurately regulated - ie doesn't drift up to over 16V with no load - then it should be safe with almost any 9V pedal. 16V is the rating on many electrolytic caps typically used in 9V pedals, and just under the limit for some chips.
    But it would be wise to check with the manufacturer first, if you can.
    To overcome this very serious problem, you should buy a new pedal that can definitely be run at 12V to be safe.
    3reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    I've sent an email and tweet to Neunaber to ask
    My Immerse can run at 12v, I think the Wet can too
    When I ran it at 12v I didn’t notice any discernible difference though
    Had a reply on twitter and Email both saying it's fine.
    It would be interesting to do proper comparisons with a real-time switch on pedals which are claimed to sound different at higher voltages. I suspect a lot of them will be less different than expected...
  • crunchmancrunchman Frets: 11459
    Digital pedals like the Nova Delay don't always play nicely when sharing power with something else.  You often get noise issues.  It's normally best to have it on it's own isolated output.
    [That's assuming it works at all.  I had two of them die on me.  Sell it before it dies and and get a Timeline or DD500.]
