Any harm?
HootsmonHootsmon Frets: 15976
Sometimes on my board i have 5x pedals connected to my cioks dc 5 and sometimes 4x
Question; is there any harm when running 4x to leave the extra cable attached in situ for lengthy periods?
Reason i be askin' is, the fella i bought the board and cioks from attached the cioks PS to the Nano right up against the side so that to remove a cable means removing the cioks!
tae be or not tae be
  • martmart Frets: 5205
    No, just try to avoid the spare cable making electrical contact with anything, eg the casing on a pedal.
  • HootsmonHootsmon Frets: 15976
    You don't get any wee safety type plugs for these ends,do you?
  • SassafrasSassafras Frets: 30294
    I use offcuts of patch cable outer jacket to slip over the plugs. Keeps them insulated (and warm).
    Eh?  those little rubber lookin' insulation jobs on the inside of a jack plug
  • djspecialistdjspecialist Frets: 908
    edited March 2019
    I'd never thought of that.  I use bits of plastic bag, held on with elastic bands. I'm willing to admit your solution is more elegant :anguished:
    Trading feedback | FS: Nothing right now
    JM build | Pedalboard plans
  • JDEJDE Frets: 1092
    I just wrap a bit of electrical tape over the tip. I’m a total slag, though.
  • CorvusCorvus Frets: 2926
    edited March 2019 tFB Trader
    Vacuum tube blanking plugs, little silicon condom efforts. Lots on ebay in multi sizes. I've used those before.
    The outer jacket of instrument cable you strip off before soldering the braided wire to a jack plug.
    Most cable has the inner diameter of a power plug.
  • vizviz Frets: 10700
    Or a bit of insulating tape. Just use some of that contact cleaner you bought for your scratchy jack socket. if it’s been on a long time.
    Thanks guys  :)
  • PolarityManPolarityMan Frets: 7293
    It'll prob open a rift int he space time continuum, if you see a green glowing vortex of doom appear in front of you then dont go through it.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    OK Gorg
    hootsmon said:
    OK Gorg
    Good cos that totally kills the top end.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
