How crackly should a new amp be?
sev112sev112 Frets: 2775
am still in discussion with the shop on this,  but just some others’ views would be good/helpful
purchased a new Fender Super Champ X2 combo.  It’s got some valves and some transistors.
gentle hum on silent which is fine.  Love most of the tones, a lot.
however with any gain, I get a crackle when ever I strum/hold a chord.  It is noticeably loud, and its volume increases with volume
It it is a continuous crackle as long as the chord is sounding; it is not a hum or a hiss.
No crackle when no sound being played
highest crackle with highest gain
increasing crackle with increased volume
(it even occurs on the clean (valve only) channel )
ive tried this in 3 different rooms, and it is still there, although slightly less.
ive tried with 3 different guitars, the same result, and I have tried 4 or 5 leads too.
how much do you think this is a faulty amp, and how much is related to the guitars and cables?
Any more testing I can do here?  I’m not a electrician.
Thanks all
  • FenderishFenderish Frets: 47
    edited May 2019
    is this your first amp ? what do you call "crackle" ?
  • sev112sev112 Frets: 2775
    First valve one. My old Marshall big combo didn’t, and my little micro cube and fly 3s don’t do similar
  • Modulus_AmpsModulus_Amps Frets: 2583
    Crackle is not normal in any circumstance.
    Don't know enough about that amp to suggest possible causes, but sounds like a faulty new amp to be returned to get sorted/exchanged
    What I’m wondering is how much is this likely to be my electricity supply, or guitars/ leads causing it.  Or whether it is the amp itself, and or whether it may have been damaged in transit
  • JezWyndJezWynd Frets: 6088
    edited May 2019
    Can you take it back to shop and test it there? From what you've described, I'd assume it has a fault.
    Could it be a bad valve?
  • webrthomsonwebrthomson Frets: 1031
    ^ This - if it's doing it with the guitar straight in and you have tried more than one lead the amp is faulty - the shop should sort out a replacement for you.
    Do they have another one? Easiest way would be to do a comparison.
  • ecc83ecc83 Frets: 1637
    Not your mains supply or it would crackle all the time.  Could possibly be a dodgy speaker, can you jack in another one?
    Does it crackle if you set the guitar down, leave a bit of gain on and thump the amp? If so, DEFFO send it back.
    Dave.
    Wonders of mail order, hence my queries before arranging for it to go back.  Thanks all. That’s what I needed :)
    Dave.
    Ok will check, I have another speaker
    Dave.
    Checked just now. Same with the other speaker.
    Light tapping with gain up generates much crackling !
  • p90foolp90fool Frets: 31621
    Wiggle the valves and apply upward pressure to make sure they're seated right - my brand new Princeton arrived with the same issue.
    If that doesn't work don't delve any deeper, send it back.
  • riverciderrivercider Frets: 461
    Bought a Blues Junior last November, it crackled a tiny bit at first, when powering up mainly, then sounded like Armageddon when you turned it on after about a week. Mini-thunderclaps, humming like crazy. Would settle down again after about 20 seconds, but glowed funny colour too.  Shop took it back, said it was a fundamental flaw they couldn't fix with simple vavle swap etc.,  they'd seen it before......gave me a new one that's been perfect.
    I used to have the same amp you bought, the X2, and don't remember having any hum at all really, it was quieter than the Junior (new one!) so I'd be inclined to exchange/replace if poss.
    just tried, no luck, but thanks anywya
  • RolandRoland Frets: 8731
    Where’s @ICBM when you need him?
    It might be a bad connection. Have you wiggled the lead, guitar jack socket and amp input socket to check that it’s not one of them? Otherwise the amp needs to go back. If it’s a faulty model then who knows what else might emerge once it’s out of its return period.
    Thanks, yes lots of wiggling done to check :) thanks
  • ICBMICBM Frets: 72477
    At actual work ;).
    No it isn't. This is a popular myth - both channels go through the DSP. But it doesn't have any bearing on it, because the power section *is* all valve, so a valve problem will show up on both channels regardless.
    The question is whether it's a valve crackle, some other crackle caused by the valve power amp, or an aspect of the digital processing that you're sensitive to (I suspect not if it does it on the clean sound).
    But as Modulus_Amps said, the first port of call is the shop. If it's still within the first 14 days they *must* take it back, regardless of whether there is a fault or not. If it's outside that, they must arrange to repair or replace it if it is faulty.
    ICBM said:
    At actual work ;).
    Cheers, (yes I knew that about the channel 1 but I was rying to distinguish from voice 1 :) )
    I’m glad my use of the word “crackle” appears to be a reasonable representation :)
    yes, 1 day old, so will be going back.
    Update.
    thanks for everyones’ advice (to what probably was a simplistic question).
    Amp is going back :( and being reimbursed,
    never mind, seeing another at 9.30 tomorrow, and a fall back available by mail order elsewhere,
    so soon be NAD :)
