Speaker swap for a Boogie Thiele cab
LewyLewy Frets: 4225
So...I've got a EVM 12L loaded Thiele cab knocking around which I used to use with a MkIII head which I haven't had for a decade. At the same time, I want a 1x12 cab to use with my Tweed Champ.
The EV is the wrong impedance and also sounds way too dark with the Champ, so I was wondering if I could just get a different speaker and stick it in the Thiele cab - something like a Jensen P12Q. Will it sound weird because of the ported cab design? Anyone tried different speakers in a Thiele?
Any thoughts welcome.
  • ICBMICBM Frets: 72408
    Yes, Mesa ;).
    They swapped from the EV to the Celestion C90 without any other change, which makes the idea that the cab was specifically tuned for the EV using the Thiele-Small parameters quite amusing :).
  • Modulus_AmpsModulus_Amps Frets: 2583
    Yes you can use it, the cab might make the bass from the champ unbearable though.
    The champ does not attenuate bass at all and all the bottom end with a ported cab might not be great, I it was me I would probably end up modding the champ to suit the cabinet. I would try mod the champ before changing out speakers. a bright cap on the volume control and reduce the first coupling cap and it should sound pretty good
    I don't know about that, my old '59 Fender 5F1 sounded incredible through a 4-ohm-wired Marshall straight 4x12" :). Yes, a lot of bottom end - but I like that, and it wasn't boomy or undefined. Like Neil Young but at slightly more sensible volume ;).
    Given that the Thiele is quite like a 4x12" in voicing, I would guess it will work fine, but it does need a 4-ohm speaker for a Champ anyway.
  • LewyLewy Frets: 4225
    Food for thought. Thanks!
    Probably depends on the speakers then, I have G12H speaker in the cab i tested it with and didn't like it, changed the first coupling cap got rid of the bass blocking distortion and made the whole thing much sweeter. horses for courses though.
    Or maybe the output transformer? The guitarist in my band had a Victoria 5112 with a G12H-30 Heritage in it, which sounded fantastic. The Victoria has bigger transformers than the stock Fender ones though.
    I can imagine if the transformer is saturating and you've got a very bassy speaker that might not sound very nice. Is it an 8-ohm speaker?
  • gordijigordiji Frets: 784
    I've never heard of an EV sounding too dark !
    I think the champ I had was built with a larger OT, this is probably just a taste thing
    I have, it was also in a Mesa Thiele cabinet
