Looking for an unusually spec'd strat body
I'd like a wrapover bridge strat with rear route control cavity and a bridge HB.. Assuming the neck pocket will have to be angled for the correct neck pitch? Or is there a slimliine wrapover bridge out there?
www.theflyingacesband.com
  • victorludorumvictorludorum Frets: 1015
    Have it routed so that you can recess the wraparound, and then you won't need to angle things.
  • MattNovakMattNovak Frets: 907
    Thanks.. I had thought of that, but it would perhaps spoil the aesthetic I was after.
    Spending the afternoon looking at thickness planers, band saws and routers... might just make my own :)
    I have a Jazzmaster body that was routed like that. Once the TOM is in, you hardly see it to be honest.
