Is it possible to improve a squier strat?
    Do you have 250k pots and are the pickups close enough to the strings?
    If all else fails will the body route support a dual humbucker pick guard?
  • LestratcasterLestratcaster Frets: 1105
    I think they're 250k pots and the pickups are approx 0.5cm close to the strings.
  • robgilmorobgilmo Frets: 3662
    Have you experimented with the pick up height? Are the three balanced?
    I actually haven't touched them since they were installed. The bridge sounds brittle and harsh whilst the 2nd position sounds the warmest.
  • HerrMetalHerrMetal Frets: 546
    Must admit I didn't consider that the Everything Axe set were humbuckers in SC size until I saw the photo then checked the SD site.
    Yeah its meant to be the JB but in a single coil size in the bridge, called a JB Jnr but I don't like it!
    With the low e held down at the last fret, the pickups should be around 2mm from the string. That’s about the right ballpark, then adjust to taste. Sounds like yours are a little further away than that.
  • HAL9000HAL9000 Frets: 9780
    Fez said:
    If replacing the pick ups again is an option I would look at Oil City pick ups. The Stone tones are great and you could have an overwound bridge pick up with a base plate. A steel tremolo block might help a bit.
    Exactly what's in my MIM Strat. Very happy with it.
  • prowlaprowla Frets: 4977
    Have a look at Iron Gear pickups. They are inexpensive but sound fantastic.
    Any particular one? They got some good reviews on there, I'm tempted to whack one set in there as they're not really expensive!
    I've got an Iron Gear Tesla Shark in a partscaster and it's rather good.
    (The guitar has a MIM body and a Warmoth neck, so a bit of a step up from a Squier, though.)
    Rabs said:
    Put a humbucker in it
    :D
    My temptation was to put a JB in the bridge, the full size one, not the Jnr.
    Funnily enough, I'm planning to put that in in place of the Iron Gear.
    The middle & neck pickups are Tonerider City Limits, which are really (really!) good.
    FYI, I've got a Squier Affinity Strat too and it's really a decent guitar; it plays like a Strat and feels like a Strat, but every part isn't quite as good as a proper Fender.
    The thing is, though, the guitar is worth under £100, so I wouldn't put money into it trying to make it into something it isn't.
  • sweepysweepy Frets: 4209
    Put a Wilkinson Vintage trem on it, solid steel block and a push fit arm, that will improve it no end
    Could you please snip the ends of the strings off the tuners?
  • mburekengemburekenge Frets: 1064
    You can improve it, but it'll never be a Marlin Slammer
  • stickyfiddlestickyfiddle Frets: 27427
    Mine. Squier Standard Strat from 2000. New neck (x4) new pickups (x3, or 4?) new bridge x3, rewired, new pickguard etc etc
    It currently has a Musikraft neck, Rio Grande pickups and a Callaham bridge. It's bloody fantastic. The body, jackplate and I think all the pickguard screws are still original :)
  • paulnb57paulnb57 Frets: 3087
    edited June 2019
    Double post....
    I woulnt expect your current set of pickups to be sooo bad, perhaps not the sound you would like, could it be they are wired incorrectly?
  • NikcNikc Frets: 629
    sounds more like an amp issue to me - what amp have you got ??
    edited June 2019
    I thought he said he tried a different amp?
    Edit, replied to wrong post!
  • rossirossi Frets: 1710
    Just sand off the headstock label and lower the pickups .Sorted .I have played loads of cheapy Squier and the pickups sound OK when lowered.Take the logo off and its not a Squier anymore so a magic tone angel makes it sound better.On the other hand the advice just play it are the best on here  and always will be .
    They’re not bad just I’ve not been 100% happy with them for reasons earlier mentioned. I had them fitted by a very well renowned guitar luthier, Stuart Monks so I should think they were fitted correctly!
    It’s a Marshall DSL5c at the moment. Hoping to get a Kemper sometime as I want to join a covers band.
