Also agree if you want a Marshall sound, and have a Marshall amp then it would be a silly thing not to use it
Thomann do a copy of the Jet city attenuator for peanuts, might be worth a try
https://www.thomann.de/gb/bugera_power_soak_ps1.htm
Still say wait for a powerbrake though (buy cheap buy twice )
Hopefully one will come up at a sensible price.
I've also tweeted to Marshall to ask if they are ever going to bring it back, maybe with an IR loader?
I've used THD Hot Plates for decades with all my vintage and vintage style amps - Vox, Fender, Marshall, Tweed stye - and while it is not a flexible solution being Ohm dependent, it is most certainly not "crap" with any of the amps. I haven't trie the others because I haven't needed to.
Wasn't impressed with either.
https://www.youtube.com/watch?v=ANFiuuY55Wk
Nil Satis Nisi Optimum
Because they like variety.
Sometimes a different bit of kit can be inspiring.
Assuming they are both passive.
I thought an attenuator was basically a bag of resistors...so what would cause them to behave differently with different amps?
Is that more to do with other circuitry e.g. 'bright' and 'warm' switches- or is there more...
Reason I ask is because I have the Rockcrusher and really not that impressed- I use it as it's what I have - but..wondering whether to try another make. Be interesting to try and understand.
Thanks
To make it even more complex, some amps seem to be more sensitive to the speaker interaction than others, and respond differently to the changes in impedance, due to elements of the power stage design, eg whether (and how much) negative feedback they have, and different transformer winding ratios. Some amps sound better with attenuators that have a flatter impedance curve, others with one that more closely mirrors the steep rise in impedance of a real speaker at high frequency - and oddly some actually sound best with purely resistive attenuators that do none of this!
It's also subjective - for example in this thread alone you will find different people who think the Hotplate sounds good, and bad, with a Marshall. Some people like the amp to sound very compressed and saturated when driven hard, others prefer a tighter, or more dynamic sound. Different attenuators will do these things even with the same amp.
I'm going to start lusting after different attenuators now...
