I haven't tried the golds so I can't say anything about them...
Currently gold + old v30.
Bandcamp
Spotify, Apple et al
I tried the Gold and V30 mix in my Trem-o-verb for a while - sounded absolutely great for clean and low-gain overdrive, but not as good as the straight two V30s for high-gain - the Gold had a metallic overtone I didn't like.
I love that overtone- it sounds to me like the speaker is trying to tear itself apart.
It is close, but it works with a Z Wreck without too many issues. I'm not really bothered about lots of gain with this amp so I think I'm going to take the gamble. If it doesn't work, I may try a Gold and a V30
I've just wired up an Orange 2 x 12 " cab with a pair of Celestions for a 60s/70s "classic rock" sound: a V30 and a G12-65.
Sounds really good but not quite as loud I'd hoped TBH - which is a bit of a surprise considering how sensitive V30s are.
yes,
@Fusionista
AFAIK the main reason for not buying higher rated speakers is that it can be cheaper, or that you want a specific design, e.g. a Celestion Blue
Some speaker types cost a lot more for the high-power versions
btw, even 1w amps sound great through a 2x12 or 4x12 fitted with high-power drivers
I know you don't intend to, but it's worth saying that the practice of overloading speaker drivers/voice coils is not guaranteed to create an attractive sound, and voice coils are expensive to replace
Did you ask Martin?
I thought the Roadstar was more suited to v30s, and the other standard Celestion rock speakers
I can try my roadstar with my 2x12 Gold for you
I am not sure Blue+ Gold will sound much different to 2xGold
The worry is that the Blue could take 80% of the power (it may have lower impedance at certain frequencies) - and self destruct. I suspect you can run them in series to stop one driver taking all the current, but even then, half of 36w is 18w
