Get H30 or 6082 grade aluminium (same thing); the normal over-the-counter grades are very soft... H30 is the old name for the grade, but still used, so look for either/both.
6082 / H30 is hard/brittle, will stay flat when cut & filed & drilled, I've used this before to make plates. Your common or garden soft ally will bend & move all over the place. But check the 6082 takes anodising OK.
