WITHDRAWN: Brunetti 059 Second Edition - Black
Not sure Brunetti is well known in this forum, don't see lot's of discussion about these italian amplifiers!
For sale is a like new condition 059 Head
New tubes included in the package
Looking for 850 GBP
This new 059, born from the evolution of the famous red
059, achieves the goal of every guitar player. It combines incredible punch with warmth and thickness. It is rich in features to make it really versatile and unique. With twenty different sound combinations and many setting possibilities you’ ll be sure to find the sound you are looking for. The power section is switchable from
20W to
100Ws using a unique double power amplifier: the 20W power section runs in class with two EL84 tubes while the 100W section runs in class AB using four EL34s. You can choose which amp to use simply with the touch of a button, or by footswitch or Midi, all in real time and it is not necessary to stand-by or switch the amp off. Playing the 20W mode you’ll have thicker tones at lower volume, while 100W mode will give you massive volume sound. The three channels of the new
059 are completely separated: the gain range of the different channels overlaps perfectly, giving you the real continuity from clean to very aggressive overdrive. Channel 1 starts with a very “clean” tone, well balanced and defined up to a fat and compressed clean, that reacts fast to your playing dynamics. Channel 2 begins where Channel 1 leaves off with a very controllable gain, great for rhythm parts with a fat and focused sound. Channel 3 is the natural step up from the Channel 2: pushing out your solo! Solos jump out of the speakers with a harmonic presence that will let you be heard in the mix, dripping with Brunetti sonic goodness. We’ve retained the original TONE REVERSE function, well known among
059 lovers and added new function named PLEXI MODE. This control activates a complex network reconfiguration providing the original sound really close to the famous British Plexi. The Plexi Mode works on each of the three channels and is midi controllable. The amp is also equipped with a simulated EMU-output, useful for recording in quite situations.
Specifications
- All tubes signal path
- Power: 20W A class (2 x EL84) and 100W AB class (4 x EL34) with separated volume controls and Presence (only 100W)
- 3 channels totally separated
- TONE REVERSE: splits the eq of CH 2 and 3
- PLEXI MODE: works on eq/gain structure
- AUX Out: EMU XLR balanced, LINE jack unbalanced, with level control, Pre out jack
- Effects Loop: for pedals and rack efx. Serial/Parallel with MIX% control. True bypass
- Tubes: 6 x 12AX7 / 2 x EL84 / 4 x EL34
- Switching: manual/footswitch/MIDI
- Weight: 17 kg
- Size: 720 x 250 x 230 mm
- Included: Footswitch, Waterproof cover, Owner’s manual, Power cable
Samples, full specs and details here:
http://www.brunetti.it/products/059/
