3 chord trick
VimFuegoVimFuego Frets: 15541
This is really embarrassing, but does anyone have a link to something that explains the 3 chord trick? i.e. what chords go with each other. I used to know all this, but it's not just physical skill you lose when you stop playing.
  • Paul_CPaul_C Frets: 7793
  • mike_lmike_l Frets: 5700
    The easy one is the standard Blues progression 1-4-5 chords.
    with the root note of the 1 chord on the low E, the root of the 4 chord will be at the same fret on the A string, the root of the 5 chord is 2 frets up from the 4 chord.
    Sorry if that badly explained.
    Or to find the chords in a major scale, the formula is
    major (root)
    minor (up 2 frets)
    minor (up 2 frets)
    major (up 1 fret)
    major (up 2 frets)
    minor (up 2 frets)
    diminished (up 2 frets)
  • VimFuegoVimFuego Frets: 15541
    that's it Paul, thanks.
  • monquixotemonquixote Frets: 17638
    I wrote a thing for Easy Ear Training on basic chord sequences which might be of interest.
    http://www.easyeartraining.com/learn/four-chords-and-the-truth/
  • 'Tis more than just blues. The I IV V chords can harmonise all the notes in the major scale. Some scale notes appear in more than one chord, eg the Tonic is the Root of the I chord and the 5th of the IV chord.
    I often use Blowin' in the wind as a f'rinstance. Dylan's original used C,F,G - I IV and V. Peter Paul & Mary's version used A-, and, IIRC D- as well being the vi and ii chords. There's a way to work the iii chord in as well. While you can "expand" the chord set of a tune that uses I IV V, you could also "simplify" a tune that uses more than I IV V and turn it into a 3-chord trick for those with a restricted chord vocabulary. This is often done in beginner's songbooks.
