All pedals true bypass, power to board on locking Neutrik Powercon connectors, locking jack sockets for pedal board to amp connection, input lead threaded through amp handle, guitar lead through strap (you'd be surprised how many don't do that!), strap locks etc etc. Its all to reduce the number of possibilites of f**k up at gig time. Its amazing how when under pressure the simplest of faults becomes a major brain spasm. Well for me anyway, not that experienced at gigging.
Without power, all electric guitars are pretty quiet.
I am sure that there must have been glitches with Variaxes, but I am equally sure that valves and fuses have blown in amps. Strings break. Paranoia only gets you so far...
So I'm paranoid now am I ????. No sorry, I have had the problem of a dead battery causing a problem so, now no batteries, I have had the problem of the powersupply getting kicked (by a punter) and all my pedals going off, so now Neutrik Powercon with PS under the board velcro'd in place. I have also seen guitarists lose their guitars mid solo because they stood on their lead which was wrapped aound the strap and pulled it off the button, and I have seen guitarists stand on their lead and unplug themselves. Thats why i use strap locks. Always got a second guitar ready on a stand incase I break a string.
I also stopped using George L's for similar reasons, I had to rip apart by board before our first set becuase I'd got a loud hum, turned out to be a dodgy end, so I now use Lava.
Its not paranoia, its common sense. Limit the possibilites for a f**k up. Enjoy the gig.......
Indeed, the PA won't work either so no gig......
You can only realistically prepare for those contingencies that you have control over. I aint taking a battery powered PA.....
