I'd flick the string too, like I do when guitaring (makes the string ring a bit more) not that I've played bass in a while.......
BTW, Jon, that C#M9 in your sig, would that work in All along the watchtower? in place of the straight C#m? I'm guessing yes, but can't think ATM
Edited the quote to read C#m9 instead of C#M9 - there's an important difference! Yes, it would work well, especially in the breakdown section with the whammy-bar swoops, with a cleaned-up tone to let the adjacent D# and E pitches in the chord ring against each other
Thanks Jon, I shall try putting it in next time I play AATW,.
It was only a slight typo, I did mean C#m9, not C#Major9, that would be wrong. Even by my standards........
Both the guitarists are playing variations on the chords, I just couldn't figure out the last bit (C-Csus-C).
The part I wanted to learn is the part Viz transcribed, as played by Michael Wilton.
The other parts could quite easily be played by the second guitarist.
