Oh for faf sake, any tips.....
......on soldering to the back of a bridge plate. I've scratched the chrome off, I've an iron that goes to 400 degrees, but still no joy making it stick.
What does it take or what am I doing wrong?
Cheers
  • ICBMICBM Frets: 72410
    Option 1 - you don't need to, just trap the wire between the body and the bridge.
    Option 2 - heat the bridge up over a gas ring - hold it with long-nose pliers! - until you can get the solder to melt onto it, then quickly put the end of the already-tinned wire into the solder blob and hold it away from the flame while it cools. (This works very well for tremolo claws too.)
  • +1 for option 1 there.
    Some more about me, my music and my record label: https://www.linkedin.com/pub/luke-crook/22/18/537
  • dindudedindude Frets: 8537
    Cool, thanks - I'm going to go for option number 1 as it's the least likely to result in me spending a sunny afternoon in A&E.
  • ecc83ecc83 Frets: 1636
    You need a 50W iron at least and some FLUX!
    Personally I would drill and tap it M3 and use a solder tag.
    Dave.
  • FX_MunkeeFX_Munkee Frets: 2478
    I've always just trapped it under the plate on a fixed bridge, as ICBM says.
    Shot through the heart, and you’re to blame, you give love a bad name. Not to mention archery tuition.
  • JD50JD50 Frets: 659
    Also a flat chisel tip on your iron helps.
