would you pay £194 for an amp stand?
I was actually looking for one with a mic holder for my combo, and stumbled upon this.
  • frankusfrankus Frets: 4719
    Nope but if I had a £1k+ amp I probably would ;)
  • SporkySporky Frets: 28416
    I probably wouldn't, given that the Proel EL700 is about £40, and the mic boom for it about £25.
  • Cripes!!! What is it made of, gold?!  I hope not, it's very ductile.
    Not to mention heavy.
    Ooops. I mentioned it.
  • monquixotemonquixote Frets: 17638
    It doesn't even look that well made.
    I'd steal a beer crate.
  • benvallbenvall Frets: 83
    edited September 2013
    I've done that, It's still in my mum and dad's garage, i saw it last weekend. Last time i bought a combo amp i got them to throw in an amp stand.
    I have a Quiklok it was about £25 and it's solid as you like.
  • It holds up to 30kg. Less than a lot of combos!
    Exactly what i'm after :-).. , but not so easy to find.
    Studiospares have them ,but unfortunately no boom arm attatchment, they appear to be like hen's teeth.
  • bertiebertie Frets: 13569
    its actually £198.........................
    I've got the mic boom but no longer need/use it...
  • ICBMICBM Frets: 72421
    Yes.
    Provided it was an amp stand with reinforced side panels, metal edges, steel corners, butterfly catches, end handles and wheels.
    Easily the best kind, and doubles as a handy amp protector as well.
    Ones for the size of amp I have do cost about that much.
    The one in the link, no. My amp weighs 45Kg for a start...
  • vasselmeyervasselmeyer Frets: 3672
    I can't imagine regularly using an amp that weight over half as much as me.
    :-)  If you're interested in selling , ..i'd like to buy it please.
    You get used to it. It's best to have two, so you're more balanced when you're carrying them :).
    Actually I cheat. My music room is on the ground floor, the amps are on wheels, and I can back the car right up to the door. At the other end... there are other band members around and that's why they have two end handles ;).
    Luckily the same is true of my bass amp, which weighs nearly 10Kg more!
