Soundhole mics Anyone using them
I have been recommended by my teacher to invest in a Audio Technica PRO70 they can go for about £97
it has a clip on device which sits on the guitar soundhole. The beauty is that you put it on any acoustic or uke or anything. Any thoughts on this
  • menamestommenamestom Frets: 4735
    I'm not, but I'd be very reluctant to use one as a single source in a live setting without very good EQ and feedback control.
    I see things like this as adding a bit of air to something less interesting that can provide a feedback resistant fundamental sound.
  • LewyLewy Frets: 4296
    I haven't used that particular one but I've used DPA and K&K clip-on mics and my experience has been that sound is great, but the practicality in all but the most ideal/forgiving live environment....patchy at best. With a good sound guy and a listening audience it's fine.
    General rule of thumb - if you'd consider doing the gig with normal condenser mic for your guitar then one of these will be the same but with added mobility. If you wouldn't consider using a normal condenser because of feedback concerns, don't use one of these either. Claims of feedback rejection due to cardioid patterns etc are grossly overstated.
  • BenSirAmosBenSirAmos Frets: 414
    I don't use acoustic on stage much but when I do I use a rare earth blend - so a magnetic sound hole pick up with a mic that sits inside and a blend control to balance between the two. Only once I remember there was too much feedback to use the mic at all.
