Back on the MR forum I started a post on using Wudtone and if it would stand up to the riggers of gigging. The test was also to show off my fan fret guitar and bass. Well the the fan fret guitar has come back after being out on loan for some time and Wudtone is OK. The same can be said for the 5 string bass. Still not sure about Wudtones longevity though but I will be using it on the necks I make but stay with Poly on the bodies I sell when making guitars to a finish. I will however use Wudtone on test guitars or on give a ways.
http://i1018.photobucket.com/albums/af305/grahamepollard/IMG_8633.jpg
http://i1018.photobucket.com/albums/af305/grahamepollard/IMG_8639.jpg
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
I'm quite a fan of wudtone. The only issue I have is the wood itself - some areas might take a bit more or less stain than others, but that's not a finishing fault, just wood being wood. I'll continue using it for most stuff, though I might try an @jookychap Paisley under gold leaf finish some day.
The neck finish on your prs build of mine is lovely - really nice to look at and hold. Nice to know it holds up
