The only thing better than a Mesa Trem-o-verb...
ICBMICBM Frets: 72485
edited April 2016 in Amps
... is two Mesa Trem-o-verbs :)
  • monquixotemonquixote Frets: 17648
    Do you take one in each hand :D
  • ICBMICBM Frets: 72485
    No, silly - they're on wheels. You strap one to each foot.
    :D
    Trem-O-skates
  • stonevibestonevibe Frets: 7157
    :D
     Please make a video of this.
  • mike_lmike_l Frets: 5700
    :D
    I assume you turn the volume up, and use the air movement as an engine*?
    *sounded funnier in my head
  • horsehorse Frets: 1571
    I like how they're about the same width as the sofa - gives a good indication of scale!
  • One on and one in the wash!
  • Dave_McDave_Mc Frets: 2360
    I see you have the same philosophy on throws and cushions on your sofa :D
  • ICBM said:
    That's fookin MENTAL, John!
    edited August 2013
    I was really tempted to post this in the 'Home Practice Gear' thread :)).
    And in fact, it works brilliantly - you get a HUGE sound at surprisingly low volume, probably around loud-ish TV levels. One amp at each end of the sofa and sit between them and you're into private-headphone-mix territory, but with real tone.
    It looks way over the top, and of course it is... or is it?! If it gives the sound you want at the volume you want, maybe it's not!
    ^ LOL
    agreed
  • Were guitarists - Practicality and common sense get left at the door along with dress sense and consideration for band members =)
  • BluesyDaveBluesyDave Frets: 411
    .....I wonder what 3 would sound like?  No that's just silly.  Nice rig btw.
    No Darling....I've had that ages.
    Wet/dry/wet rig like Brian May with his AC30s!
    But you're thinking too small :). I was already wondering what four would be like :D.
    One for each mode, so it could be set for optimal output valve/rectifier/power level etc as well...
    ......and Steve Morse.
    Like your thinking.
    Meant to ask.....How the hell did you get it past Mrs ICBM?
    Easy... it doesn't live in the room with the sofa normally, it's in my workshop. It didn't actually cost me anything directly either - it was what was left at the end of a very long chain of deals and swaps with friends. I'm not sure if she even knows it's mine really!
    And since the two look the same (now I've swapped the knobs and the light on the 'new' one), it's not instantly obvious there's more than one if they're not in the same room.
    That said, I need to be careful... I once had an old Marshall chassis lying in the hall, with the rarer Plessey filter caps, and she walked past it and said "Aren't those green things normally blue?" :)
  • olsols Frets: 10
    DiscoStu said:
    Three words: Not loud enough ;)
    You clearly have the technique down to a very fine art.......respect.
