Non hardwired on/off switch for me router table
Chaps, I'm probably being thick, but Google is giving me nowt of use.
Does there exist an on/off switch that I can attach to me 'shady homebrew' router table, that I can plug my router into, and plug the other end into a socket?
If such a thing exists, where can I find it?
Obliged.
  • FelineGuitarsFelineGuitars Frets: 11615
    I use a trend no volt release switch - although I use it on my buffing machine
    http://www.trenddirectuk.com/nvrs-2-240v.html
    It will only allow the power to be on if there is voltage there
    in the event of a power out it will switch the switch off and not let the power back through without a deliberate manual restart.
    Seriously sensible safety feature
  • RoxRox Frets: 2147
    I've got an extension lead with an inline RCD that does a similar thing.
  • jd0272jd0272 Frets: 3867
    That's what I'm after, cheers Jonathan.
    Aye I'd considered that, but I'd end up being at a gig with mine still attached to me table.........  ;)
  • SambostarSambostar Frets: 8745
    edited August 2014
    There are cheaper thing on ebay.  I know what you mean, you don't want to hardwire your router so you can remove it with the base for other overhead jobs and you really need a kill button (NVR Switch) (No Volt Release I guess it stands for) in case a mahogany splinter penetrates your forehead whilst routing.  Just get something rated for the router's power.  Do a search for a NVR Switch and run it to a socket, both mounted on the side of your table.
    http://www.ebay.co.uk/itm/Woodturning-Woodworking-No-Volt-Release-Switch-NVR-2HP-16A-/251550307115?pt=UK_Crafts_Other_Crafts_EH&hash=item3a9191132b
    Just get a 12mm bit of ply and mount a triangle between you support beam and joist at the corner, rout an insert for it and screw it down.  Cover the back with a screwed on deep household socket backbox with a drilled knockout and use a compression gland for the knockout to fix the cable.  Earth everything.  Does seem a tad small although will do the job.
    http://www.axminster.co.uk/axminster-nvr-switch?gclid=COuyjvnzqMACFUjHtAodqEMALw
    Found this one too, although no knee button.
    but this one does.
    http://www.axminster.co.uk/axminster-emergency-stop-nvr-switch?gclid=CPTg16L0qMACFabLtAodbBwANA
    Backdoor Children Of The Sock
