If they are, the best fix is to wrap some thick card around them for protection and use pliers to extract them.
If that fails - very rare - it means the peg is so jammed that almost nothing will remove it and you'll probably have to drill it out.
There's no point in trying to pull it out from the top since you'll either chew up the bridge, snap the head off the peg, or both.
But I've never had a pinned bridge acoustic until I bought a Taylor- my others were thru-bridges.
Fender String Winder
It works perfectly, much betterer than the Planet Waves one that I also have.
Nil Satis Nisi Optimum
I usually gently push the base of them with the flat side of a pair of longnose pliers now (as per sweepy's suggestion).
Trading feedback: Previous (+18) and Current
