If you are happy to change them then buy a set from Ebay and swap the all out.
As said, a guitar store is your best bet, they will help with advice and re-stringing, its hard to give advice without knowing all the details, in a store they can see your guitar.
I also take it they are tie ends rather than ball ends.
http://www.ebay.co.uk/itm/Set-6-pro-CLASSICAL-GUITAR-STRINGS-normal-or-high-gauge-tension-nylon-acoustic-/191303710920?pt=UK_Guitar_Accessories&var=&hash=item2c8a96f8c8
It's important to realise that this is a *classical* guitar, not an *acoustic* guitar. That was the mistake I made too.
