wiring question.
Hello, Looking for a bit of advice from any one who's good with a soldering iron :)
I'm wiring a guitar with one volume, two tone and 3 way switch. I'm going to make both tone pots push/pull so I can coil tap both humbuckers. I'm going to follow the digram below, and I just wanted to know I do at the area marked in red. Do I solder a joint here and run wires in the way shown. I'm just doing some pre at the moment as I'm waiting for my pickups to arrive. So ANY advice would be great.
Thanks in advance. Mark
  • ICBMICBM Frets: 72415
    Make the connections on any of the terminals that those wires go to - it doesn't matter which, or even all the same one - don't join the wires exactly where they're shown. It's just a convention to make the diagram easier to read.
  • markblackmarkblack Frets: 1591
    @ICBM  Thanks, that makes sense now to point it out. First time trying this, but I figure you can't learn if you don't try :)
    Remember, when you've never done something before there are no stupid questions, just stupid assumptions. Don't feel embarrassed to ask!
    The only stupid question is the one you didn't ask - so they say..
