Bagpipes
HHwarnerHHwarner Frets: 137
edited October 2014 in FX
Im pretty green when it comes to effects as I usually only use an OD for a solo boost. For a particular song (I wonder if you can guess which song) we do we have access to a Bagpipe player but not all of the time. Is there a pedal I could use to play the bagpipe bits on lead? I play through a JMP 2203 or JCM 800 Marshall. Thanks in advance
  • GassageGassage Frets: 31018
    edited October 2014
    Noise gate. Set it to mute.
  • HHwarnerHHwarner Frets: 137
    @ Gassage. Yes I like that ha ha
  • ICBMICBM Frets: 72767
    edited October 2014
    lol
    A Boss PS-5 should be close. Stuart Adamson used an MXR Pitch Transposer - an early rack-mount pitch shifter - to get his distinctive bagpipe-like sound in Big Country.
    To do it really well you need something that will produce a drone as well, a Boss DF-2 will do that, although you have to hold it down for the whole time you want the drone.
  • martmart Frets: 5205
    HHwarner said:
    ... I wonder if you can guess which song ...
    It's Sweet Child o Mine, isn't it?
  • ..or just play the same notes but on a guitar and don't get hung up on aiming for the exact same sound (cos none of your audience will care)
  • EricTheWearyEricTheWeary Frets: 16303
    Big Country used the MXR M129 and Bruce Watson still does, apparently. Mike Oldfield had some wacky thing built for him. EBows get mentioned as one way to do the bagpipe thing.
  • don't play the song, "they" didn't... not once the pipes had been damaged iirc
    My trading feedback
    It's a long way to the top!!!! Cheers for the suggestions guys I'll have a play
    Just a thought, with the lack of a loop, would either the above be ok in front of tha amp. If so would it come before or after the od boost
    On the original recording Scott couldn't play it so what you are hearing is mostly tape manipulation anyway. IIRC.
    It doesn't have to sound bang on just near enough and something to fill the space a bit
    We love to play it. It's a real crowd pleaser ;-)
    We did discuss an electric pipe :-)
    Just another thought is there a pedal you can load and save samples in?
    Plenty of loopers will do that easily.
    I know a guy in a Who tribute who have the "Won't Get Fooled" and "Baba O'Riley" synth bits sampled and played from a Boss looper.
    You can store sample loops set to single-play in the Digitech JamMan Solo XT. With an additional footswich you can even step up/down through presets on the fly. It's USB linkable to your computer so you can do all your editing etc. on the computer and then load it onto the looper.
