That whole stacked reverse+regular delay thing that I bang on about... (clips)
Drew_TNBDDrew_TNBD Frets: 22445
@Samzadgan asked me about this today, so I thought I'd just throw some clips out.
First clip is from our track 'Wake':
https://dl.dropboxusercontent.com/u/630473/GearDemos/DrewTacoma_ReversedDualDelay.mp3
Second clip is from our track 'Black Iron Prison':
https://dl.dropboxusercontent.com/u/630473/GearDemos/Drew_BlackIronBreakdown.mp3
Effectively what I go for is a sort of Eventide 'crystals' effect but without the pitch shifting. So you get these undulations below the main guitar tone, and their strength kinda depends on how distorted the amp is. In the Wake clip, the amp is clean... in the BIP clip, the amp is set to a crunch without boost tone.
If you listen to the albums, you can hear I double tracked these parts. It particularly obvious with the BIP section, because the delays jump around the stereo field creating this wobbly almost dubsteppy kind of sound.
You can't get this effect with just one delay, because it requires the push and pull of the two delays. It doesn't work in parallel either, they have to be in series and the reverse delay has to go first.
So that's it really. Kind of obvious when you think about it.
  • Dave_McDave_Mc Frets: 2359
    That's pretty cool. You can definitely hear the sort of "push-pull" type thing going on with the repeats.
  • danodano Frets: 1594
    edited November 2014
    That second track is great Drew @drewfx, definately given me an inspiration to get out a second delay pedal (and maybe a third and a fourth !) and have an experimentation this evening.
    Did you have the repeat time on them set the same or double / half on the second ?
    Set just about the same Dano.
  • Paul_CPaul_C Frets: 7794
    which pedals?
    Doesn't really matter to be honest. But it was a Hardwire DL-8 and a Line 6 DL-4 at the time of recording.
  • Cool sound
    only got to listen to those tracks today @drew_fx...on the wake song, it took me a while to hear the reverse delay..i guess when its stacked it washes it out a little, which is cool...i adds a lot of space to the sound.
    alot more pronounced on the scond track...but again because its stacked it takes the edge of the weirdness. I like it.
    In the times i've used it, its been reverse on its own, and i just didnt see the useability of it...but in the context of stacking, its pretty cool.
    Yup. Stacked for reals. I *never* use reverse delay on its own.
  • I must say, that sounds very good indeed. I sense an evening of delay-flavoured M9 fun coming on :)
    Tracks if you're interested in how it works in the context of a song:
  • mike_lmike_l Frets: 5700
    Why not?
    Doesn't work for you/your material or just plain sounds bad?
    mike_l said:
    Why not?
    Mainly because it never worked for our material in the past. Not averse to trying it in the future.
    Ah, cool. Thanks Drew, I think I'll have a play with the reverse on my DD-6 at some point, see what if I like it.
    Kinda want a DD6 for the warp feature!
  • littlegreenmanlittlegreenman Frets: 4996
    Which reminded me @Drew_fx that I never did get around to buying Exegesis. Just bought the digipack from your Bandcamp site, downloading now and look forward to fondling your CD soon ;)
    And buying another delay!
    littlegreenman < My tunes here...
    Appreciate it :)
