Pedal Board Junction Box
im looking to finish my new board off with a simple junction box, so I can connect everything up neatly and it act as a start and end to the chain.
I'm not sure after having a look around whether to go for a plastic or metal enclosure or what wire type I would best be going for to keep things as noise free as possible.
Can anyone with a bit more knowledge on the electrics front than I have point me in the right direction?
Thanks for any help
Simon
  • RockerRocker Frets: 4987
    The less connections the better. From guitar to first pedal, anchor the cable near the pedal with a cable tie. Same with cable to amp. Fold the cables into the pedalboard case after use.
    Nil Satis Nisi Optimum
  • Not even thought of that, that would work! I've got a pedal train so everything would go underneath out the way making setting up a little quicker too.
