Replacement case latch
GuitarseGuitarse Frets: 165
edited November 2014 in Guitar
Pissed off to have somehow managed to shear one of the latches off my Gibson SG case the other night. Anyone know a) a supplier for a replacement and b) is it aggro replacing it?
Cheers
Never ever bloody anything, ever!
  • ADPADP Frets: 184
    What kind is it? I replaced part of one on a Fender case. I might be able to help.
  • stuagustuagu Frets: 334
    I've got a latch or two... U got a pic?
  • GuitarseGuitarse Frets: 165
    OK. Cheers guys.
    This is how it is now...
    ..........and this is how it should be.....
  • ICBMICBM Frets: 72821
    If you've still got the other bit you should be able to fix it, although it still means getting the baseplate off the case and re-rivetting it afterwards, which is the biggest pain in the arse about this job…
    I'm pretty sure there's no way of getting those tabs to fold round tightly without being able to get at the back of it.
    I've lost the other bit. Not sure if it's worth the hassle as I will need to disturb the lining, drill out the old rivets and replace them too. It's quite a new case and in good nick so just a bit gutted at my own carelessness really.
    If got something very similar... Pm me an adres and il ping it over
    You shouldn't need to drill out the rivets - they're split-shaft types folded over on the inside, once you've got the lining out of the way you can undo them and re-use the same ones when you put the latch back. A bit of glue and some clothes pegs to clamp it and you won't even see the lining has been off.
    It's a bit of a faff, but not really that hard.
  • I'm just putting this out there...
    My two 2010 custom shop Gibson cases are the worse cases i've every used.
